TLicense Posted November 4, 2010 Share Posted November 4, 2010 If someone has a crankshaft position trigger wheel, and a vernier to hand could they take a couple of measurements off of it for me? I'm interested in knowing the total diameter of the timing wheel (ie tip of one tooth, to the tip of the opposite tooth) The second measurement I'm looking for is the actual length of the tips of the teeth. From that I can work out the angles of the teeth and gaps. Many thanks! Tony Quote Link to comment Share on other sites More sharing options...
Miguel Posted November 4, 2010 Share Posted November 4, 2010 (edited) 76mm tip to tip. 66.05mm trough to trough. 5.02-5.08mm Tooth tip width. Edited November 4, 2010 by Miguel (see edit history) Quote Link to comment Share on other sites More sharing options...
TLicense Posted November 4, 2010 Author Share Posted November 4, 2010 Top man, thanks Mig. Quote Link to comment Share on other sites More sharing options...
