Guest wantthatone Posted November 3, 2010 Share Posted November 3, 2010 my jspec has drivers & passenger airbags, should there be a warning light showing this when you turn the ignition on? i need to remove the steering wheel & i understand you need to reset, but surely the warning light would show when you turn the ignition on, any help please guys:search: Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted November 3, 2010 Share Posted November 3, 2010 could the reason be its just un plugged somewhere, instead of resetting it was disconnected? is the connection under the horn pad?? if anyone is awake help!! Quote Link to comment Share on other sites More sharing options...
nevins Posted November 3, 2010 Share Posted November 3, 2010 There will be a warning light on the right bank of lights, also you can remove and install an air bag with out having to reset it fella Quote Link to comment Share on other sites More sharing options...
nevins Posted November 3, 2010 Share Posted November 3, 2010 also disconnect the battery when taking the wheel off. Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted November 3, 2010 Share Posted November 3, 2010 i dont have any warning lights on when i turn the ignition on?! Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted November 3, 2010 Share Posted November 3, 2010 i noticed on another "warning light" thread, it shows the airbag light by the odometer on the left side?? Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted November 3, 2010 Share Posted November 3, 2010 sorry i have all the warning lights except the airbag one on turning the ignition on Quote Link to comment Share on other sites More sharing options...
nevins Posted November 3, 2010 Share Posted November 3, 2010 one of them fella lol. but the operating function is when the ignition is turned on the light will illuminate for 3 seconds then go off. If its not coming on at all its a good chance that the bulbs been removed. Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted November 4, 2010 Share Posted November 4, 2010 bloody hell this car! how do i check the bulb? Quote Link to comment Share on other sites More sharing options...
nevins Posted November 4, 2010 Share Posted November 4, 2010 The top section of the dash with the lights in has iirc 6 screws holding it in, remove these then remove the multi plugs from the rear of the displays. You can now see where the bulbs fit in. The easiest way to check is hold it up to the light and see what ones light up with the light entering the open bulb spaces. If the air bag appears then the bulbs missing if it doesn't then check the bulbs for a blown one. Quote Link to comment Share on other sites More sharing options...
