nur spec and double decat uk
suprababy
Darren, as I see it, Suprababy has already had a decat done, and is now looking to get a sports exhaust fitted.
As Branners said, no logical reason as to why the exhaust shouldn't bolt straight on - you certainly don't want to be putting any cats back!
I no about megan down pipe's i have one i got it from the usa NOW i no it does not fit TT jap spec but was told that it fit's uk tt if you look at parts 4 sale is the one the same it will replace both cat's if not then only one cat replacement
Ive got a Nur spec and double decat on my UK spec car, however be aware the UK's will only boost to around .9 bar even with these mods.
So you will need a boost controller to get higher boost! although doing just the above will improve the breathing and defo the sound :woot:
Dave :thanks:
Dave :thanks:
Mine didn't!!! :tongue:
oh right, on a UK a megan racing pipe, does both cats and will make your NUR spec hang quite low, i mean lower than the stock cats do, but it will fit. Will sound sexy too!!!
DO IT!
