Dr_Doom Posted November 2, 2010 Share Posted November 2, 2010 Following on from this thread; http://www.mkivsupra.net/vbb/showthread.php?t=232324 I'm in need of a set of J-spec turbos, or at least the 2nd one. Can anyone help? Thanks, Rob. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 2, 2010 Share Posted November 2, 2010 you do know you can swap cores so either turbo is fine.. Link to comment Share on other sites More sharing options...
RobD Posted November 2, 2010 Share Posted November 2, 2010 I may know someone with a spare set of tubbies, I think one of the turbine fins is chipped on one though! Any good? I'll get in touch with him later once I've finished work Link to comment Share on other sites More sharing options...
Dr_Doom Posted November 2, 2010 Author Share Posted November 2, 2010 you do know you can swap cores so either turbo is fine.. I didn't know that. Is it a specialist job to swap? Link to comment Share on other sites More sharing options...
Dr_Doom Posted November 2, 2010 Author Share Posted November 2, 2010 I may know someone with a spare set of tubbies, I think one of the turbine fins is chipped on one though! Any good? I'll get in touch with him later once I've finished work Sounds promising! If you can let me know what he says & what sort of condition theyre in that would be great Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 2, 2010 Share Posted November 2, 2010 I didn't know that. Is it a specialist job to swap? not really but i would say that, (any comptent mechanic can do it just make sure when you remove the casting you dont damage blades).. we have done it before and it works.. i have some turbos here some have very small chips on blades..(if you cant find any that is) as last resort. Link to comment Share on other sites More sharing options...
Dnk Posted November 2, 2010 Share Posted November 2, 2010 Wont a chipped blade just vibrate itself to death fairly quickly ?? just asking not digging at anyone Good luck with getting this sorted Rob Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 2, 2010 Share Posted November 2, 2010 Wont a chipped blade just vibrate itself to death fairly quickly ?? just asking not digging at anyone Good luck with getting this sorted Rob possibly not ideal but i have heard of cars here with chip turbo blades doing ok and lasting a while but its not IDEAL. Link to comment Share on other sites More sharing options...
RobD Posted November 2, 2010 Share Posted November 2, 2010 Wont a chipped blade just vibrate itself to death fairly quickly ?? just asking not digging at anyone Good luck with getting this sorted Rob Like jurgen said, it's not ideal but if he keeps at a sensible boost they will be ok and get him out of a tight spot Link to comment Share on other sites More sharing options...
Hoppy Posted November 2, 2010 Share Posted November 2, 2010 I also used an old 2nd turbo as a replacement first turbo, and it worked a treat. The fins were chipped on both my turbo's, but they still lasted ages. Although they did go in the end, hence my single turbo conversion. Link to comment Share on other sites More sharing options...
Dnk Posted November 2, 2010 Share Posted November 2, 2010 Like jurgen said, it's not ideal but if he keeps at a sensible boost they will be ok and get him out of a tight spot I was just thinking of the labour involved in fitting and removing them, personally i'd rather do it once. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 2, 2010 Share Posted November 2, 2010 I was just thinking of the labour involved in fitting and removing them, personally i'd rather do it once. yep i agree with you 100% but sometimes these turbos cost £50 as opposed to £350plus.. its just for someone in a tight spot.. if your running 1.2 bar then its a no no Link to comment Share on other sites More sharing options...
Dnk Posted November 2, 2010 Share Posted November 2, 2010 yep i agree with you 100% but sometimes these turbos cost £50 as opposed to £350plus.. its just for someone in a tight spot.. if your running 1.2 bar then its a no no Totally understand Jurgen but is there any point in running less than 1.2 bar Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 2, 2010 Share Posted November 2, 2010 Totally understand Jurgen but is there any point in running less than 1.2 bar Link to comment Share on other sites More sharing options...
RobD Posted November 2, 2010 Share Posted November 2, 2010 Totally understand Jurgen but is there any point in running less than 1.2 bar Boost junkie! Link to comment Share on other sites More sharing options...
Hoppy Posted November 2, 2010 Share Posted November 2, 2010 Boost junkie! Are'nt we all Link to comment Share on other sites More sharing options...
RobD Posted November 2, 2010 Share Posted November 2, 2010 Are'nt we all No doubt I will be in a couple of months once my engines in Link to comment Share on other sites More sharing options...
Hoppy Posted November 2, 2010 Share Posted November 2, 2010 Link to comment Share on other sites More sharing options...
Dnk Posted November 2, 2010 Share Posted November 2, 2010 Well once you've had 1.2 + then anything else is just an NA Link to comment Share on other sites More sharing options...
Hoppy Posted November 2, 2010 Share Posted November 2, 2010 :yes: Link to comment Share on other sites More sharing options...
Dr_Doom Posted November 2, 2010 Author Share Posted November 2, 2010 Good luck with getting this sorted Rob Thanks Dunk! I know what you're saying about not wanting to do the job twice. Trying to find a set of perfect condition J-spec ceramic turbos is a bloody nightmare though Especially as most of the cars are 15years old now. I think i might have to make do with an 'ok-ish' set for now, as long as the seals are ok and they don’t smoke. It's very rare i get to run the car on full boost at the moment as there aren't any big roads near me and also the weathers likely to be crap for the next few months. Link to comment Share on other sites More sharing options...
Carl Posted November 2, 2010 Share Posted November 2, 2010 you should of seen my turbo blades after i removed them. Id say about a third of some of the blades were missing yet the car ran fine and pulled like a train at 1.2bar. hopefully itll pull like two trains when I put the replacement ones in. Link to comment Share on other sites More sharing options...
Dr_Doom Posted November 2, 2010 Author Share Posted November 2, 2010 you should of seen my turbo blades after i removed them. Id say about a third of some of the blades were missing yet the car ran fine and pulled like a train at 1.2bar. hopefully itll pull like two trains when I put the replacement ones in. To be fair, i bet that most people running J-spec turbos have chips in them and never even realise. 15 year old turbos & fragile ceramic blades aren't a great combination. Link to comment Share on other sites More sharing options...
