Set of J-Spec Turbos
Dr_Doom
I may know someone with a spare set of tubbies, I think one of the turbine fins is chipped on one though! Any good?
I'll get in touch with him later once I've finished work :)
Sounds promising! If you can let me know what he says & what sort of condition theyre in that would be great ;)
I didn't know that. Is it a specialist job to swap?
not really but i would say that, (any comptent mechanic can do it just make sure when you remove the casting you dont damage blades)..
we have done it before and it works..
i have some turbos here some have very small chips on blades..(if you cant find any that is) as last resort.
Wont a chipped blade just vibrate itself to death fairly quickly ?? just asking not digging at anyone :)
Good luck with getting this sorted Rob
Like jurgen said, it's not ideal but if he keeps at a sensible boost they will be ok and get him out of a tight spot :)
I was just thinking of the labour involved in fitting and removing them, personally i'd rather do it once.
yep i agree with you 100% but sometimes these turbos cost £50 as opposed to £350plus..
its just for someone in a tight spot..
if your running 1.2 bar then its a no no
Totally understand Jurgen :) but is there any point in running less than 1.2 bar :innocent::D
Thanks Dunk! ;)
I know what you're saying about not wanting to do the job twice. Trying to find a set of perfect condition J-spec ceramic turbos is a bloody nightmare though :) Especially as most of the cars are 15years old now.
I think i might have to make do with an 'ok-ish' set for now, as long as the seals are ok and they don’t smoke. It's very rare i get to run the car on full boost at the moment as there aren't any big roads near me and also the weathers likely to be crap for the next few months.
you should of seen my turbo blades after i removed them. Id say about a third of some of the blades were missing yet the car ran fine and pulled like a train at 1.2bar.
hopefully itll pull like two trains when I put the replacement ones in.
To be fair, i bet that most people running J-spec turbos have chips in them and never even realise. 15 year old turbos & fragile ceramic blades aren't a great combination. :)
