HKS Hipermax standard/ballpark settings
RobSheffield
i have the above, and they are definately not to standard settings
could someone post up some settings ( i assume they are compression/rebound and the spring collar/spring rate adjustment)
even if you dont consider them to be 'standard' setings, im simply after a ballpark idea where the settings should be so im not bouncy as you like at the front, and hard as f**k at the rear!
cheers
Rob
