Guest lesparkman Posted November 1, 2010 Share Posted November 1, 2010 some of you guys have to know aprox what i should be seeing?? here is the spec after a bit of fiddling:- factory 2jz gte engine other than this gt35r .82 tial 44mm waste gate 850cc injectors link management Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted November 1, 2010 Share Posted November 1, 2010 Around 550bhp at 1.4 bar Quote Link to comment Share on other sites More sharing options...
magictorch Posted November 1, 2010 Share Posted November 1, 2010 550.....600 max Are you auto or manual? Quote Link to comment Share on other sites More sharing options...
davej705 Posted November 1, 2010 Share Posted November 1, 2010 About 500bhp?? Depends on other bits like manifold fuelling exhaust Quote Link to comment Share on other sites More sharing options...
Nic Posted November 1, 2010 Share Posted November 1, 2010 See my garage HERE I was running a GT35R AR .82 full spec is listed and there's a dyno graph at 1.3bar. Quote Link to comment Share on other sites More sharing options...
Nic Posted November 1, 2010 Share Posted November 1, 2010 Around 550bhp at 1.4 bar Should be something close to that with cams fitted. Mine made around 530hp at 1.3bar. Quote Link to comment Share on other sites More sharing options...
Guest lesparkman Posted November 1, 2010 Share Posted November 1, 2010 550.....600 max Are you auto or manual? its a manual cheers guys is 1.3-1.4 with in the safe bracket was thinking of setting high boost at 1.5, would that be pushing it! /turbo/internals? and low about 1.2 as the link has a switchable map Quote Link to comment Share on other sites More sharing options...
Nic Posted November 1, 2010 Share Posted November 1, 2010 I use to run 1.4bar on a freshly rebuilt stock engine, I wasn't interested in squeezing every last hp out of mine, it was set up and mapped to be reliably quick Quote Link to comment Share on other sites More sharing options...
Guest lesparkman Posted November 1, 2010 Share Posted November 1, 2010 I use to run 1.4bar on a freshly rebuilt stock engine, I wasn't interested in squeezing every last hp out of mine, it was set up and mapped to be reliably quick its good to know that its still reliable at 1.4!! some people say that they are good for up to 1.8 so i thought 1.5 would be enough like yourself to keep it reliable Quote Link to comment Share on other sites More sharing options...
