what power should it make????
Guest lesparkman
Guest lesparkman
some of you guys have to know aprox what i should be seeing??
here is the spec after a bit of fiddling:-
factory 2jz gte engine other than this
gt35r .82
tial 44mm waste gate
850cc injectors
link management
Guest lesparkman
550.....600 max
Are you auto or manual?
its a manual
cheers guys
is 1.3-1.4 with in the safe bracket
was thinking of setting high boost at 1.5, would that be pushing it! /turbo/internals?
and low about 1.2 as the link has a switchable map
Guest lesparkman
I use to run 1.4bar on a freshly rebuilt stock engine, I wasn't interested in squeezing every last hp out of mine, it was set up and mapped to be reliably quick :)
its good to know that its still reliable at 1.4!!
some people say that they are good for up to 1.8 so i thought 1.5 would be enough like yourself to keep it reliable
