marbleapple Posted October 31, 2010 Share Posted October 31, 2010 Evening guys, Sorry for the potentially dumb post but I have been wondering whether it is possible to transplant a TT engine into a 5 speed manual and use the manual box? - I presume you can but I have not seen many around and wondered why? I presume there may be problems with reliability and will require modification etc? I read somewhere that there are advantages of having 5 speed boxes over 6 speed boxes due to the gear ratios. If anyone knows of useful threads re this topic I would be grateful for links. Thanks Ric Link to comment Share on other sites More sharing options...
Havard Posted October 31, 2010 Share Posted October 31, 2010 Dr Doom is the only one I know personally to have this done I think he is on his third box though..... H. Link to comment Share on other sites More sharing options...
dcarrter21 Posted October 31, 2010 Share Posted October 31, 2010 I buggered my box, was the way I drove it though! Should last a fair while if driven carefully. I'm going 6 speed now though, just need a clutch! Link to comment Share on other sites More sharing options...
Blackie Posted October 31, 2010 Share Posted October 31, 2010 I buggered my box! Is that all you got up to at the weekend Dave? Link to comment Share on other sites More sharing options...
Supra Gaz Posted October 31, 2010 Share Posted October 31, 2010 I have heard a good clutch and not to much boost will keep the box intact.... For a while anyway, getrag 6 speed manual is the one to have, expensive though. Link to comment Share on other sites More sharing options...
supracars Posted October 31, 2010 Share Posted October 31, 2010 Yes you can mate, and use the same box. Not too complicated to do. Keron probably the best man for advice as he has done loads. This set up certainly makes the car feel a lot nipper and more responsive to drive at lower speeds as opposed to a tt6 Link to comment Share on other sites More sharing options...
supracars Posted October 31, 2010 Share Posted October 31, 2010 I have heard a good clutch and not to much boost will keep the box intact.... For a while anyway, getrag 6 speed manual is the one to have, expensive though. i agree... RPS max clutch is a good one to go for Link to comment Share on other sites More sharing options...
marbleapple Posted October 31, 2010 Author Share Posted October 31, 2010 Yes you can mate, and use the same box. Not too complicated to do. Keron probably the best man for advice as he has done loads. This set up certainly makes the car feel a lot nipper and more responsive to drive at lower speeds as opposed to a tt6 Thanks. My thoughts are that N/A's are so cheap at the moment it's close to 3/4 times cheaper to buy a 5 speed N/A with a manual 5 speed than a 6 speed TT. I note people talk a lot about 6 speed boxes but I am 'just' wanting a bog standard TT I don't know what the need is? (unless I am missing something?) I have heard a good clutch and not to much boost will keep the box intact.... For a while anyway, getrag 6 speed manual is the one to have, expensive though. From what i have seen they cost more than an N/A. Are the 5 speed boxes so weak they can't take a TT? Link to comment Share on other sites More sharing options...
The Raven Posted October 31, 2010 Share Posted October 31, 2010 Vicky ran her N/A with 5 speed. They should hold stock TT power all day long. Link to comment Share on other sites More sharing options...
marbleapple Posted October 31, 2010 Author Share Posted October 31, 2010 Vicky ran her N/A with 5 speed. They should hold stock TT power all day long. Would you happen to know if much modificaiton was needed? Concious of what Havard has said earlier on in the thread. Link to comment Share on other sites More sharing options...
supracars Posted October 31, 2010 Share Posted October 31, 2010 standard tt power shouldn't cause too much trouble, ive run a bpu with a w58 for around two years with no probs at all, It is also an idea to put a manual conversion in a TT auto?? You will end up with a higher spec car in the end, and also the TT auto diff ratios will effectively cancel out the missing 6th gear, giving you much higher top end speed and economy as opposed to a N/A diff and w58 box. Link to comment Share on other sites More sharing options...
The Raven Posted October 31, 2010 Share Posted October 31, 2010 I know keron converts TT with 5 speeds, as does dude. However if i was you i would dump a soarer engine in much cheaper mates up with the w58 box too. Link to comment Share on other sites More sharing options...
marbleapple Posted October 31, 2010 Author Share Posted October 31, 2010 standard tt power shouldn't cause too much trouble, ive run a bpu with a w58 for around two years with no probs at all, It is also an idea to put a manual conversion in a TT auto?? You will end up with a higher spec car in the end, and also the TT auto diff ratios will effectively cancel out the missing 6th gear, giving you much higher top end speed and economy as opposed to a N/A diff and w58 box. I like kitted cars. Kitted 6 speed TT's are mega £. Kitted N/A's seem to be quite cheap. I just wanted to explore the option of dropping a TT into the manual N/A. I am not a fan of auto's. Nothing to do with the box itself, more to do with the fact that I like to feel 'involved' when driving which i don't seem to get with autos. I must concede though that I have never driven a TT auto. Link to comment Share on other sites More sharing options...
marbleapple Posted October 31, 2010 Author Share Posted October 31, 2010 I know keron converts TT with 5 speeds, as does dude. However if i was you i would dump a soarer engine in much cheaper mates up with the w58 box too. Aren't they 2.5 though? I presume they are not at powerful as a Supra TT? - All a bit technical for me. I presume a W58 is the 5 speed gearbox? Link to comment Share on other sites More sharing options...
The Raven Posted October 31, 2010 Share Posted October 31, 2010 Num should be able to tell you all about the soarer lump Link to comment Share on other sites More sharing options...
little num Posted October 31, 2010 Share Posted October 31, 2010 (edited) Aren't they 2.5 though? I presume they are not at powerful as a Supra TT? - All a bit technical for me. I presume a W58 is the 5 speed gearbox? hmm NOW we are talking, i have fitted a 2.5tt into my mkiv (vid somewhere ill find it out) and with bpu its close to 380 and revs like a monster, smoother power as the both turbo's come on together at 2.5 thou revs and are fully in at 3 thou and lasts right upto 7.8 thou. And fitted driectly to my W58, also as there is no rush like the 3.0 tt the box will last longer due to it being smoother power. With the 1JZ there are some wiring to do where as the 2JZ plugs right in, but either way you will need a TT rev counter as the N/A dont work. here is the link to the vid. http://www.mkivsupra.net/vbb/showthread.php?t=216371 I can supply a complete 1JZ TT with most parts needed for the MKIV and info to get it running from £750 - £850 depending on spec, so alot cheaper the 2JZ and with 440cc injectors in will hit 400hp with 420fbs torque, and lighter then the 2JZ and also sits lower in the car as its a shorter block. Edited October 31, 2010 by little num added vid. (see edit history) Link to comment Share on other sites More sharing options...
davej705 Posted October 31, 2010 Share Posted October 31, 2010 How much power can the 5speed handle? I agree about autos,although being a good autobox,the make you feel less involved Link to comment Share on other sites More sharing options...
Havard Posted October 31, 2010 Share Posted October 31, 2010 Would you happen to know if much modificaiton was needed? Concious of what Havard has said earlier on in the thread. Hi dude, sorry to cause any worries. It was something I was going to have done by Keron myself until the VVTi came up. I thought that Dooms car was ok until I spoke to him recently. Rob does push his car hard though, although I don't see the point of having turbos if you are frightened to use them... There must be plenty of people on here that have experience. H. Link to comment Share on other sites More sharing options...
marbleapple Posted October 31, 2010 Author Share Posted October 31, 2010 (edited) hmm NOW we are talking, i have fitted a 2.5tt into my mkiv (vid somewhere ill find it out) and with bpu its close to 380 and revs like a monster, smoother power as the both turbo's come on together at 2.5tho revs and are fully in at 3 tho and last right upto 8 tho. And fitted driectly to my W58, also as there is no rush like the 3.0 tt the box will last longer due to it being smoother power. With the 1JZ there are some wiring to do where as the 2JZ plugs right in, but either way you will need a TT rev counter as the N/A dont work. here is the link to the vid. http://www.mkivsupra.net/vbb/showthread.php?t=216371 So arguably, if one was going down the N/A route a soarer TT manual would be a good idea? Do all Manual Soarers come with the W58 box? Having a quick look on eBay, there doesn't appear to be that many manual soarers about. Hi dude, sorry to cause any worries. It was something I was going to have done by Keron myself until the VVTi came up. I thought that Dooms car was ok until I spoke to him recently. No problem. I appreciate you taking the to post. It is one of those things I thought about when I had my old manual N/A but I sold it before I ever asked the quesiton. I spent so much making it look how I wanted, it would have seemed silly to scrap it and start again with a new TT car. Edited October 31, 2010 by marbleapple (see edit history) Link to comment Share on other sites More sharing options...
The Raven Posted October 31, 2010 Share Posted October 31, 2010 How much power can the 5speed handle? I agree about autos,although being a good autobox,the make you feel less involved I wouldnt run them over stock TT power with a normal clutch 320bhp Link to comment Share on other sites More sharing options...
marbleapple Posted October 31, 2010 Author Share Posted October 31, 2010 I wouldnt run them over stock TT power with a normal clutch 320bhp But that isn't necessarily a big problem is it? Buying a uprated clutch I mean. Link to comment Share on other sites More sharing options...
davej705 Posted October 31, 2010 Share Posted October 31, 2010 I wouldnt run them over stock TT power with a normal clutch 320bhp What about with a clutch that could handle more? Could the box handle more Link to comment Share on other sites More sharing options...
The Raven Posted October 31, 2010 Share Posted October 31, 2010 Im sure people have run BPU cars though the w58 not sure how long they lasted. Link to comment Share on other sites More sharing options...
marbleapple Posted October 31, 2010 Author Share Posted October 31, 2010 Im sure people have run BPU cars though the w58 not sure how long they lasted. Sorry... W58 = N/A 5 speed? Link to comment Share on other sites More sharing options...
The Raven Posted October 31, 2010 Share Posted October 31, 2010 Sorry... W58 = N/A 5 speed? Yeah mate. W58 is a n.a 5 speed box. Link to comment Share on other sites More sharing options...
