supra steveo Posted October 31, 2010 Share Posted October 31, 2010 not to happy about it but carolines supra failed its MOT today for the sidelights not being bright enough , they were some poxy LED ones and fair enough they werent great but when we tried some normal bulbs in they failed to work so i think it needs some new bulb holders , one of the number plate bulbs had gone too but that was an easy fix but these bulb holders on the front dont want to play at all do toyota normally keep these in stock as if i can prove that they work tomorrow they will pass it free of charge Link to comment Share on other sites More sharing options...
scotty71 Posted October 31, 2010 Share Posted October 31, 2010 if thats all it failed on thats good right?? Link to comment Share on other sites More sharing options...
Graham S Posted October 31, 2010 Share Posted October 31, 2010 not to happy about it but carolines supra failed its MOT today for the sidelights not being bright enough , they were some poxy LED ones and fair enough they werent great but when we tried some normal bulbs in they failed to work so i think it needs some new bulb holders , one of the number plate bulbs had gone too but that was an easy fix but these bulb holders on the front dont want to play at all do toyota normally keep these in stock as if i can prove that they work tomorrow they will pass it free of charge In theory, as long as they are both as bright as each other it should be fine... But ask the tester to show you in the testers manual what is defined as bright enough!! Link to comment Share on other sites More sharing options...
Scott Posted October 31, 2010 Share Posted October 31, 2010 What about giving the contacts a rub to see if that helps with the standard bulbs? Just to get it through its test. Link to comment Share on other sites More sharing options...
Graham S Posted October 31, 2010 Share Posted October 31, 2010 What about giving the contacts a rub to see if that helps with the standard bulbs? Just to get it through its test. make some connectors to fit them together! Bodge it dude to get it through! Link to comment Share on other sites More sharing options...
supra steveo Posted October 31, 2010 Author Share Posted October 31, 2010 ive got no tin foil but ive also tried rubbing the contacts down and they were having none of it am livid , so is caroline coz she needs this to pass tomorrow coz she needs to drive back up north Link to comment Share on other sites More sharing options...
Graham S Posted October 31, 2010 Share Posted October 31, 2010 Who lives the closest to you that you could borrow some for the day! Link to comment Share on other sites More sharing options...
supra steveo Posted October 31, 2010 Author Share Posted October 31, 2010 i am just out side of Bury St.Edmunds, Suffolk Link to comment Share on other sites More sharing options...
Scott Posted October 31, 2010 Share Posted October 31, 2010 Are they facelift? I don't think the pre-facelifts unplug, do they? Best of it is I'm sure I have a couple of these somewhere. I wouldn't for the life of me know where, and clearly they are no use to you being up here, I just found it typical though Link to comment Share on other sites More sharing options...
supra steveo Posted October 31, 2010 Author Share Posted October 31, 2010 haha CONTACT!!!! cunning plan ......... wait out !!! in other words ive got an idea back in 10 Link to comment Share on other sites More sharing options...
supra steveo Posted October 31, 2010 Author Share Posted October 31, 2010 Are they facelift? I don't think the pre-facelifts unplug, do they? Best of it is I'm sure I have a couple of these somewhere. I wouldn't for the life of me know where, and clearly they are no use to you being up here, I just found it typical though yes they are facelift Link to comment Share on other sites More sharing options...
Scott Posted October 31, 2010 Share Posted October 31, 2010 Is it a facelift car? If not, have the original sidelights been removed? Link to comment Share on other sites More sharing options...
supra steveo Posted October 31, 2010 Author Share Posted October 31, 2010 Is it a facelift car? If not, have the original sidelights been removed? the front end has been fully facelifted i.e highlights, indicators Link to comment Share on other sites More sharing options...
Scott Posted October 31, 2010 Share Posted October 31, 2010 I'm guessing the sidelight wiring was extended for the facelift indicators then? Are you sure the bulbs are working? If LED's light up in the holder then normal bulbs should work fine. Link to comment Share on other sites More sharing options...
supra steveo Posted October 31, 2010 Author Share Posted October 31, 2010 i know but they arnt must just be a bad conection or something Link to comment Share on other sites More sharing options...
Scott Posted October 31, 2010 Share Posted October 31, 2010 i know but they arnt must just be a bad conection or something Or bulbs that don't work. Have you checked the bulbs? You have to look at this logically and not overlook simple steps. If one bulb works, the connection is good.... they should all work. Have you tried swapping the LED's over to see if the light stays dimmer at the same side, this would maybe go part of the way to explaining why a normal bulb wouldn't work, low power for some reason. Very unlikely though. Link to comment Share on other sites More sharing options...
supra steveo Posted October 31, 2010 Author Share Posted October 31, 2010 right guys just been over the hanger (so i am not lying down in the wet) and OMG its like spaghetti junction behind the bumper the is loads of wire coiled up and cable tied, the wires have been joined with the stuff i normally see behind walls in houses with the 2 screws on them, anyway brand new bulbs and the wiring tidyed up a little and still no light any SME's on here Link to comment Share on other sites More sharing options...
KrisM Posted October 31, 2010 Share Posted October 31, 2010 Best of luck with the fix! You must of given the tester a dirty look though Link to comment Share on other sites More sharing options...
supra steveo Posted October 31, 2010 Author Share Posted October 31, 2010 i am not going to that place again Link to comment Share on other sites More sharing options...
supra steveo Posted November 1, 2010 Author Share Posted November 1, 2010 anyone know where is the fuse for the sidelights ? Link to comment Share on other sites More sharing options...
Scott Posted November 1, 2010 Share Posted November 1, 2010 anyone know where is the fuse for the sidelights ? I thought the sidelights were working? The LED versions? If they are then it's not the fuse. Link to comment Share on other sites More sharing options...
