richarde7927 Posted October 30, 2010 Share Posted October 30, 2010 I have used the search botton and read on the net now for 2 hours and the info i have found does not seem to be right , I have a j spec tt6 and im trying to fit APEXI S-AFC Just for the display really , The problem i have is that i cannot get an rpm feed and ignition signal I have look at wiring diagrams and they are saying E10 ,16 or another i looked at was E9 , 58 for the rpm and E10 ,1 for the ignition switch ,as its worded ,I have used these and no look . Could someone point me in the right direction of the good pinout one they no is right or tell me the numbers and plugs of the wires i need . Thank you for your time Rich. Quote Link to comment Share on other sites More sharing options...
Ian C Posted October 30, 2010 Share Posted October 30, 2010 This is the way my sAFC was successfully wired up ages ago: Brown -> B69 (nearest ECU) Black -> B69 (nearest loom) Red -> A31 Green -> B58 Yellow -> ECU side of B62 White -> Loom side of B62 Grey -> B43 Blue -> unused Pink -> ununsed Orange -> unused Yellow and White I believe are the airflow signal, don't attach them or cut the B62 wire if you are only using the display features of the sAFC. The attached picture shows which plug is A (E10) and which is B (E9) and the associated pin numbers. If you didn't get an RPM signal off B58 then you either did it wrong somehow or you've got bigger problems as your ECu sin't seeing an RPM feed either -Ian Quote Link to comment Share on other sites More sharing options...
richarde7927 Posted October 30, 2010 Author Share Posted October 30, 2010 Thank you mate for your help , I have just been back outside for another go and its sorted . Thanks again Rich. Quote Link to comment Share on other sites More sharing options...
