Inferno Posted October 30, 2010 Share Posted October 30, 2010 As the documentation of the build is complete (click HERE for the build thread), I thought it would be appropriate to put the photoshoot in this section as it is no longer a Project, but now officially my Ride I have also included the spec list and a list of people I wanted to thank for all of their hard work, efforts, and time spent on the car. Quote Link to comment Share on other sites More sharing options...
Inferno Posted October 30, 2010 Author Share Posted October 30, 2010 Quote Link to comment Share on other sites More sharing options...
Inferno Posted October 30, 2010 Author Share Posted October 30, 2010 Car on the dyno Video: Roberuta Cup Kit Video: Number Plate Flipper Video: Quote Link to comment Share on other sites More sharing options...
Inferno Posted October 30, 2010 Author Share Posted October 30, 2010 Exterior: Genuine Top Secret Hood Whifbitz Front Bumper (Modified for widebody conversion, widened, smoothed, reinforced and extended) Custom Fabricated Steel TRD style widebody rear quarter Fenders Fuel tank & door delete Rear Wiper Delete Antenna Delete Rear washer Nozzle Delete Filled Rear Number Plate Hole OEM fuel system delete (Fuel cap, flap, fender portion) MVP TRD Widebody Kit (Minus front Bumper, rear fenders and wing) RMM Carbon Fibre TRD Wing New OEM Side Mirrors New OEM Door Handles New OEM front and rear fender trim and liners Black mesh inserts for TRD front fender vents New OEM side skirt vent/brake cooler trim New OEM front, rear, side window and pillar mouldings New oem front, rear, side and quarter glass/windows New OEM emblems (toyota, turbo, supra, toyota logo) New OEM headlights New OEM tail lights New OEM 3rd brake light New OEM indicators Numberplate flipper Modified rear TRD bumper for dual exhaust Clear OEM headlight conversion LED tail light conversion Undercoating and sound deadening - interior floor, undercarriage, wheel arches New 97+ Turn Signals Custom plug and play harness for 97 turn signals using OEM parts Full bare metal respray in PPG Super Black with PPG Clear Undercarriage resprayed New subframes, powdercoated Wheel arches resprayed Engine bay resprayed Interior/chassis resprayed Engine Bay: Top secret hood dampers Hose Techniques Kit - Black New OEM Relay block + Covers new OEM Ignitor + Bracket New OEM Relay holder New OEM radiator relay new OEM traction control / ABS relay New OEM oil filter cap New OEM water outlet, gaskets, hoses, pipes, New OEM valve stem seals New Oil hoses, clamps New OEM charcoal canister, tubes and lines (later deleted) New OEM water pump hoses, pipes, clamps New OEM Windscreen washer assembly, bottle, nozzles, tubes, wipers (later deleted) New OEM bonnet latches/hooks New front fender to cowel seal New front louvre/cowl Undercarriage: Custom Made Engine Under Cover Custom Belly Pan Powerhouse Racing Front Radiator Panel - Chromed SP ABS Cover - powdercoated SP Master Cylinder Cover - powdercoated Painted Fuse Box Cover New OEM spark plug cover SP Chromed upper radiator pipe TTC Performance ABS relay cover - powdercoated TTC Performance Aluminium Ignitor cover - Chromed TTC Performance Brake - Chromed Power Steering Cap - Chromed Chromed Radiator Clamps Interior: 2006 Toyota Celica GTS Steering Wheel New OEM indicator stalk 6sp Shifter and console conversion Passenger Airbag conversion (replaced upper glove box with supra scripted airbag) Sparco DTM Carbon Fibre, Leather and Alcantera Seats Sparco Brackets, Sliders, Sidemounts, seatbelt brackets/tabs New OEM Black Carpet New OEM Black Roof Carpet New OEM Rear Vision Mirros New OEM Visors New OEM Pillar Trim Custom Rear Seat Delete with center mounted 10" subwoofer New OEM Centre Console New OEM Centre Console Lid Leather Covered centre console + lid New OEM Coat Hooks New OEM Jesus Handle New OEM Hand Brake Assembly New OEM Dash Pad New OEM traction control button, front active spoiler switch blanking plates New OEM warning gauges/indicators New OEM clock New OEM Dash Pad New OEM Dash pieces New OEM Door Panels New rear interior plastics (ALL) New OEM door handles + trim + switches New OEM Door stoppers New OEM Centre console New OEM lower glove box TRD 10k Tach TRD 320km/hr Speedometer New OEM Tach / Plastic lense covers New boot trim, rubber stoppers, door cards, boards, lining, stoppers, hinges New OEM rear hatch struts Sound deadened, repainted floor New rocker panels, scuff plates/boards, mouldings New rear boot carpet New accelerator, brake pedals, food rest LED dash conversion Suspension: NEW OEM Power Steering Rack and boots Top Secret Roberuta Cup Kit (Front + Rear + Remote) HKS Drag Coilovers IKEYA FORMULA Front Upper Control Arms IKEYA FORMULA Front Lower Control Arms IKEYA FORMULA Rear Member spacers IKEYA FORMULA Rear Upper Control Arms IKEYA FORMULA Rear Lower Control Arms IKEYA FORMULA Rear Toe Adjuster Rods IKEYA FORMULA Traction adjuster rods IKEYA FORMULA Lower Link Bushes Solid Left and Right Differential Ear Mouns Sub-Assembly Solid Mounts Rear Weld-In Steel Sub-Assembly Mounts Solid Rear Subframe Mounts Sway Bar End Links TRD Front and Rear Sway Bars powdercoated Custom Drag Alignment Fall Line Motorsports Race Balancing and Alignment New OEM knuckles new OEM wheel spindles/hubs (front knuckles, rear axle carrier assemblies) New OEM Tie Rod assemblies New OEM rear suspension cushions New OEM camber adjustment rods New oem front and rear axle shaft/wheel bearings Titan Differential Ear Mounts front Titan Differential Mounts Rear Titan Solid Rear Subframe Mounts Titan Solid Rear Subframe Mounts for Sway Bars Brakes: Rotora 12 Piston Calipers, 380mm 2-piece Drilled and Slotted Rotors Rotora 4 Piston Calipers, 355mm 2-piece Drilled and Slotted Rotors Goodridge Stainless Steel Brake Line Kit New OEM Brake Master Cylinder New OEM Brake booster vacuum pipes/hoses New OEM Parking brake assembly New OEM Parking brake cables, clamps, retainers, lever, New OEM brake dust covers New OEM Parking brake shoes Wheels/Tyres: HRE 895R 19x10 Front, 18x12.5 Rear, Gloss Charcoal Powdercoated Centers, Polished Lips 2 265/30ZR-19 Michelin Pilot Sport PS2 XL 2 P345/30R-18 BFGoodrich g-Force T/A Drag Radial Engine: New OEM Toyota Shortblock New OEM Toyota Cylinder Head HKS 3.4L Stroker Kit MVP Built Stroker - Line Honed, Bored, Decked, Reworked Oil Passages, new factory thrust washers Shimless Buckets PHR CNC Ported and Polished Race Cylinder Head Ferrea Dual Valve Springs Ferrea Titanium Retainers Ferrea Valve Guides Ferrea Valve Locks Ferrea Valve Seals Ferrea +1mm Titanium Valves Ferrea Spring Seat Locators HKS 1.6mm Stopper Metal Head Gasket L19 ARP Head Stud Kit ARP Main Crank Stud Kit JUN Camshafts 256 intake 9.3mm lift JUN Camshaft 264 exhaust 9.3mm lift JUN Cam Gears (was Unorthadox Racing) Power Enterprise F-1 Rod Bearings (Brown) Power Enterprise F-1 Crank Bearings (Green) Power Enterprise Center Bearings SP 1200cc Injectors SP Custom pump hanger SP Custom Pickup SP Fuel Pressure Regulator SP Fuel Filters SP Fuel Rail Weldon 2035 Fuel Pump Weldon Fuel Pump Controller Braided stainless steel fuel lines Titan Billet Main Caps ALL NEW OEM Parts for building OEM longblock New OEM Cylinder Head Covers (Valve Covers) - Modified for breather kit and chromed New Screws, Bolts, Washers, Gaskets, Piping, Clamps, Threads, Nuts New Oil Pan - Chromed New Oil PAn Baffle Plate New Oil Guage/DipStick Dipstck Chromed Cap New OEM Timing Belt Cover - Chromed New OEM Rear Engine Oil Seal New Camshaft Oil Seal New Valve Ventilation Hoses New OEM Timing Belt Guide New OEM Tensioner Assembly PHR EGR Block Off Plates PHR Billet Timing Belt Tensioner Bracked - Chromed New Crank/cam position sensors TTC Performance Idler pulley - chromed Unorthatodx Racing Alternator Pullley - Chromed New OEM Power Steering Pump Unorthadox Racing Power Steering Pulley - Chromed Unorthadox Racing Water pump pulley - Chromed TTC Waterpump pulley cover - chromed TRD 160 Degree Thermostat Unorthadox Racing Lightened Pulley Set - Chromed PHR Modified Oil Pump PHR Engine Breather Kit (First Ever RHD!) - Chromed with Nickel Fittings ATI Crank Pulley HKS Timing Belt Greddy Oil Catch Tank - Chromed Powerhouse Racing Alternator Upgrade for 1993-98 Supra - 175 Amp - Chromed TRD Engine Mounts - Chromed New OEM Engine Mount Brackets - Chromed NGK Iridium Spark Plugs New OEM Coil Packs TRD Oil Cap Electronics: New engine wire harness New engine bay wire harness New OEM Harnesses PROEFI 128 ECU ProEFI Wideband Sensor ProEFI AIT Sensor ProEFI MAP Sensor ProEFI Wiring Harness ProEFI CAN Bus Gauge ProEFI Oil Temperature Sensor ProEFI Oil Pressure Sensor ProEFI Transmission Oil Temperature Sensor ProEFI Transmission Pressure Sensor ProEFI Nitrous Pressure Sensor ProEFI Fuel Pressure Sensor ProEFI Exhaust Back Pressure Sensor Custom Battery Box Battery Relocation 0 gauge Wiring New Idle Control Motor Custom Distribution Block Python Model 592 Responder HD Alarm System with Remote Start and Automatic Window Roll Up New Airbag sensors Racelogic Traction Control with Launch control and digital adjuster Grounding Kit Fuel/Nitrous: PROEFI Controlled Dry Nitrous 125 HP Kit Purge Kit Custom Secret Nitrous Box Billet Bottle Brackets - Chromed Custom Fuel Pumps + Controllers SP Fuel System Custom Fuel Cell with functioning factory level sender unit OEM Fuel System Delete Weldon 2035-A Billet 180gph, 1800hp, -12 inlet, -10 outlet Weldon Dial a Flow Fuel Filter 40Micron Fuel Filter 10Micron Intake: Custom SP Intake Manifold - Chromed Custom Intake Piping - Chromed ProEFI Throttle Body - Chromed New TPS Sensor New Throttle Cable and Wheel Adapter Tial 50mm BOV Dual turbo intake filters Exhaust: Custom SP sequential Exhaust Manifold Custom Downpipes Custom 3-4" Midpipe, Dual Exhaust 4" High Flow Stainless Steel Cat SP Boost Activated Exhuast Cutout SP Custom twin wastegates Turbo: SP Custom 5" Thick race Intercooler - Chromed Custom Intercooler Piping - Chromed Sound Performance FULLY CUSTOM FABRICATED SEQUENTIAL TWIN TURBO SYSTEM with DBB Garrett GT3071R 53mm - Chromed (.78 a/r T3 3 inlet) SP Custom sequential turbo kit with dual quick spool valves. Transmission: New OEM Flex Plate New OEM Rear Driveplate Spacer New OEM Front Driveplate Spacer Powerhouse Racing 4.27:1 Ring and Pinion Gear Set TRD Auto LSD New OEM Speed Signal Sensors New OEM Axles 3.75" ACPT Carbon Fiber Driveshaft SP 4L80E Transmission Conversion 3200 Torque Converter 4L80E Deep Transmission Pan Quote Link to comment Share on other sites More sharing options...
Harry Sachs Posted October 30, 2010 Share Posted October 30, 2010 That is immense!!!! By far my favourite car on the forum. Quote Link to comment Share on other sites More sharing options...
Inferno Posted October 30, 2010 Author Share Posted October 30, 2010 Accessories/Cooling/Other: New OEM Radiator New OEM Radiator fan and shroud 2 B&M Polished Aluminium SuperCooler 20500 BTU 11"x8"x1.5" Automatic Transmission Coolers Meziere Electric Water Pump Aluminium Overflow Coolant Tank - Chromed New OEM Spindles New OEM Wheel Hubs New OEM Steering Column New OEM Steering Wheel switches New OEM Steering Column Cover New OEM Ebrake Parts New OEM Tie Rod Ends Bellhousing Chromed Chromed Bolts Chromed Braces Chromed Brake Vacuum Lines Chromed Over Flow Tank Number Plate Flipper New OEM Air conditioning assembly New OEM A/C Compressor SP Oil Cooler Kit SP Remote Oil Filter Kit Audio: Pioneer AVIC-F10BT GPS In Dash Car Solution Focal 100 VRS Front Seperates Focal 165 VRS Rear Seperates Focal Solid Amps MTX Shallow 10" Subwoofer TT6510 Custom Sub Enclosure Thank you to: EVERYONE at Sound Performance (Chris, Larry, Reid, Vince) Joel @ Golden Hammer Auto Body Dusty, Robert & Kevin @ MVP Joe & Jarrett @ PHR Curt @ Elmhurst Aaron @ Import Monster Paden @ Unique Automotive Johan @ JRD Kean & Zohair @ Boost Logic Bottle & Nero @ Titan Guy Atherton @ HRE James @ Castle Hill Toyota Rory @ NZ Toyota Gaz @ Envy Brian @ RB Chroming Dan @ Speedware Motorsports Andre (dre99gsx) Stu Hagen Nic the Import Pimp Si (Heckler) Gary (suprattgaz) Bradley and RHDJapan Fall Line Motorsports Nengun Greenline Japan The Tire Rack Spinto Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted October 30, 2010 Share Posted October 30, 2010 Proper that is, love that twin exit exhaust, have you got any pics of your fuel tank? Nice front bumper by the way, nice to see one on a car on the other side of the world. Quote Link to comment Share on other sites More sharing options...
Nic Posted October 30, 2010 Share Posted October 30, 2010 (edited) David she looks stunning, very jealous buddy Edited October 30, 2010 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted October 30, 2010 Share Posted October 30, 2010 im very jealous too, i quit bling now seems pointless with yours and hodges lol. Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 30, 2010 Share Posted October 30, 2010 Holy mother of mercy That interior is just I dare not see the final bill Quote Link to comment Share on other sites More sharing options...
Inferno Posted October 30, 2010 Author Share Posted October 30, 2010 Proper that is, love that twin exit exhaust, have you got any pics of your fuel tank? Nice front bumper by the way, nice to see one on a car on the other side of the world. Thanks Paul! Pics of the fuel tank are in the build thread - it is a custom fuel cell/pump setup! Here is just one of them: Quote Link to comment Share on other sites More sharing options...
davej705 Posted October 30, 2010 Share Posted October 30, 2010 This is one of my favourite supra's and a big credit to you Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 30, 2010 Share Posted October 30, 2010 Tasty car, We need a speedo video:cool: Quote Link to comment Share on other sites More sharing options...
Abz Posted October 30, 2010 Share Posted October 30, 2010 Words can not even describe this Supra, I'd go as far as saying, one of the best.... In The World So please keep hold of it until I get rich enough to buy it off you! Quote Link to comment Share on other sites More sharing options...
marcAB10 Posted October 31, 2010 Share Posted October 31, 2010 A work of art! Quote Link to comment Share on other sites More sharing options...
KrisM Posted October 31, 2010 Share Posted October 31, 2010 Attention to detail is spectacular. Very impressed. Quote Link to comment Share on other sites More sharing options...
DARETT Posted October 31, 2010 Share Posted October 31, 2010 Car looks amazing, great effort from SP. It's truly one of a kind. Quote Link to comment Share on other sites More sharing options...
3LL Posted October 31, 2010 Share Posted October 31, 2010 I have only one thing to say... I just came... Thats is all.. Quote Link to comment Share on other sites More sharing options...
Rich Posted October 31, 2010 Share Posted October 31, 2010 UNBELIEVABLE car! Quote Link to comment Share on other sites More sharing options...
little num Posted October 31, 2010 Share Posted October 31, 2010 You need a wife, as then she would spend all of your money. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted October 31, 2010 Share Posted October 31, 2010 Outrageous car mate Must be fantastic to drive Quote Link to comment Share on other sites More sharing options...
Ricky49 Posted October 31, 2010 Share Posted October 31, 2010 Very nice indeed. I would love to know the overall cost of this build. Well done to all. Quote Link to comment Share on other sites More sharing options...
Brazil Posted October 31, 2010 Share Posted October 31, 2010 You've pushed the bench mark way...! up there...! Come on guys..! let's try to reach half way..! LOL Quote Link to comment Share on other sites More sharing options...
SupraHuman Posted October 31, 2010 Share Posted October 31, 2010 Best Supra ever, period!! Quote Link to comment Share on other sites More sharing options...
Matt H Posted November 1, 2010 Share Posted November 1, 2010 Really is an unbelievable build. Quote Link to comment Share on other sites More sharing options...
