Cylinder misFiring
Jellybean
You could try taking it for a run and then pulling the plugs to see if there's one that is obviously different in colour - there may be no noticeable difference but it's worth a try. If you're sure the coil packs and connectors okay, try fitting a fresh set of plugs to see if it cures the problem.
Just changed the Plugs on Saturday, no joy
Found plug one oil on her but looks like the Cam Seals are weeping and god knows for how long could be up to a year
The clips, I call them plugs, they do plug into the coil after all lol :) If it was fine before and youve disturbed them then its logical thats the cause :)
It started two weeks ago so taught it was the spark plugs, but replacing them didnt solve it, so New breather Cam pipes and Clips , I will see if the clips do the trick
Anything else obvious i should check?
Was it misfiring before the plug change? If so, was it running fine before with the old plugs and then just started to misfire? Have you changed anything else, eg. increased the boost?
Got full service everything done at Supra Specialist over here a few weeks ago , running great then two weeks ago she wont go over 1.0 bar ;.0.9 bar Nothing changed or touched
Miss fire, so this is why I changed the plugs , they where last done at the start of the Summer
Okay just double checking is wasn't plug related. If it was running fine before and suddenly started misfiring and you've replaced with new plugs of the same spec then that rules them out.
You mentioned oil when you removed the plugs, did you replace the cam cover seals? When you get the coil pack connectors done check for oil again if they weren't replaced.
Its gonna be spark related, breaking down under load, coil pack or clip
Agree, probably the connectors if they haven't been replaced.
Right on,
Step 1) Follow Ian C's guide to refreshing the coil pack connector contact
Step 2) Swap a set of coilpacks in from a known working high boost engine
Step 3) Swap an ignitor from a known working car just to eliminate
Didnt do the seals or clean up the oil in the spark plug well if thats what u call it
Breather pipes need replacing so waiting on them too
Dont know if it matters but it appears to happen only after 2nd tubbie comes online 3500-4K rpm
Is it ok to use autoglym engine cleaner to clean up the oil with the spark plugs still in ?
Right on,
Goin with Ian's Guide alright, I will get the SuperSpark coil packs next I think
No other Supra's around here I am afraid to try parts so it will be up SSI if the clips dont work
