psymon Posted June 14, 2005 Share Posted June 14, 2005 My front windscreen washer does not wash. The bottle is full and the rear washs normal. Is there a pump for the front and one for the rear or are they both from the same pump. I have disconnected the hose that connect to the bonnet and still no water. Any ideas. ta Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted June 14, 2005 Share Posted June 14, 2005 I have the same problem however the rear one works but the front one doesnt i think its the pump - would be intresting to know how easy to replace the pump would be ? Quote Link to comment Share on other sites More sharing options...
Stonkin Posted June 14, 2005 Share Posted June 14, 2005 Silly question maybe, but the washers aernt blocked are they, have you tried poking a pin in them? Just a thought? Christian Edited to say, sorry, didnt read that you had disconnected the hose to the bonnet already, back to square 1! Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 14, 2005 Share Posted June 14, 2005 There is only one pump with a trick valve system (I think) that means when the pump spins one way it does the front screen, and when it spins the other way it does the rear screen. My front stopped working once and simply unplugging and replugging the connector on the pump fixed it - the "front-squirt" pin had a bad connection. If you can squirt the rear screen chances are the pump isn't buggered (unless it's the valve system). The squirty bottle is located in front of the passenger side wheel, and the pump is a push-fit into the rear of the bottle. You need to jack the car up and take the wheel off, then remove the front section on the inner arch liner and it's staring you in the face behind that. -Ian Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 14, 2005 Share Posted June 14, 2005 Silly question maybe, but the washers aernt blocked are they, have you tried poking a pin in them? Just a thought? Christian Easiest thing to check for is the whining of the pump when you press the button If it whines, there is a blockage. If it doesn't, there is a pump problem. -Ian Quote Link to comment Share on other sites More sharing options...
Aerotop Dave Posted June 14, 2005 Share Posted June 14, 2005 You are pressing the button on the end of the stalk and not just pulling the lever back towards you? Yes it's obvious and insulting, but both dude and myself made this mistake Quote Link to comment Share on other sites More sharing options...
Guest Egon Posted June 14, 2005 Share Posted June 14, 2005 Same as Aerotop Dave... felt stupid after figuring you don't pull it towards you like conventional cars. Just figured it the other day... felt proud afterwards Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted June 14, 2005 Share Posted June 14, 2005 You are pressing the button on the end of the stalk and not just pulling the lever back towards you? Yes it's obvious and insulting, but both dude and myself made this mistake Add Paul E to that list as well...... Quote Link to comment Share on other sites More sharing options...
psymon Posted June 14, 2005 Author Share Posted June 14, 2005 Oh the humiliation God I can't remember the last car which had a button on the end of the stalk. Thanks guys. Talk bout being humble at the mo....... It works just fine Thanks. I'll get me coat Quote Link to comment Share on other sites More sharing options...
Aerotop Dave Posted June 14, 2005 Share Posted June 14, 2005 I can see the headlines now: Aerotop Dave Beats Ian C in Technical Problem Solving Battle Quote Link to comment Share on other sites More sharing options...
Nic Posted June 14, 2005 Share Posted June 14, 2005 If anyone needs a pump I have a spare one off the car I stripped. Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 14, 2005 Share Posted June 14, 2005 I can see the headlines now: Aerotop Dave Beats Ian C in Technical Problem Solving Battle I type all that in and it's the old "button-what-button" gag I think I fell for that almost exactly the same way last time as well. In fact, it was probably you I typed it in for.... -Ian Edit to say - nope, it was Paul E I did the explanation for - and we can add Loks and StealthHosts to the list of shame Quote Link to comment Share on other sites More sharing options...
Aerotop Dave Posted June 14, 2005 Share Posted June 14, 2005 Dunno what you're talking about mate... http://www.mkivsupra.net/vbb/showthread.php?t=20698 Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 14, 2005 Share Posted June 14, 2005 OMFG I fall for it every time LOL -Ian Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted June 14, 2005 Share Posted June 14, 2005 You are pressing the button on the end of the stalk and not just pulling the lever back towards you? Yes it's obvious and insulting, but both dude and myself made this mistake woops that be sorted then Quote Link to comment Share on other sites More sharing options...
