Cam Shaft Seals & Cam Cover Seals
Jellybean
I think my Cam cover Seals need replacing, but talking to Paul Whiffin; can somebody expalin where the Cam Shaft Seals are?
CAm Cover Seals look like easy enough job to do but what about the Cam Shaft Seals?
Any advice on how to do the seals always welcome ;)
If you take a look at my valve stem seals thread, although you obviously don't want to change the stem seals, I also go through how to change the camshaft and cam cover seals.
If you need the seals, just by pure coincidence I have a genuine Toyota set here that I'm not going to be using.
Ah ok so it is covered in the Valve Stem Seal replacement Thread
Thanks for the offer but Paul Whiffin got back to me on prices, only fair I buy them through Paul
