TT pipework question
Razak
I was just looking under the bonnet the other day and happened to spot what looks like a peice of hose that has been cut and had a section removed, now god knows i didnt do it.
I was nosing around on here looking to see what it does and i believe its for an actuator on the turbo setup. The one labelled "To Actuator" on the following picture, but i could be mistaken (found in a thead posted by Ian C)
Photo from my bay
http://img.photobucket.com/albums/v169/Razak/CIMG0239.jpg
Now if i am correct, i assume this isn't right, what would the effect be?
Thats the vsv for the pre-spool of the second turbo. Like that in you pic will cause the second turbo to come on later than it should. Just reconnect it!
Thanks, i was planning on, it does look cut though so ill need to replace it, which i will asap
