AEM PH, Greddy profecB, External WG,UK ECU, BPU plugs, T4 turbo, J spec TT fuel pumps
David Reid
AEM peak and hold unit
Bought from Terminator to use with my AEM unit which didnt work so I never used it. Copy and paste of the advert:-
Used AEM 10 channel peak and hold driver works perfectly.
Used but supplied with brand new leads and fitting pack full printed instruction.
Used instead of a resistor pack to make low duty of low imp injectors easier to control.
Complete kit; two brand new looms, new fixing kit, but I recommend soldered connections, new fuse and holder, instructions and the all important AEM sticker. If the buyer wanted to use soldered connections, I'll chuck in enough shrink wrap for the job. If you have RACE LOGIC TC this unit is wired between the ECU and the RL connections.
Note the serial number. Early AEM P&H drivers had problems with the circuit board. The problem was fixed on Serial no's 300 and upwards.
I just want what I paid £105 delivered
Greddy Profec B Boost controller
Just removed from my car as the Syvecs ECU is now handling boost control.
£120 delivered SOLD
T4 Hybrid turbonetics
Forsale T4 hybrid turbo, I used this on my drift car and should be good for 500 bhp. I was pulling 1bar by approx 3000 rpm.
Now the bad bit, unfortunated I didnt check the oil feed before fitting and it had a restrictor, and I starved the core or oil. But its journal bearing so an easy repair, turbonetics quoted £250 to rebuild.
Or I think (and dont garrentee) you could buy this either of these rebuild kits/core and do a cheap rebuild then just have it balanced.
New core £65
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120520457691&ssPageName=STRK:MEWAX:IT
Rebuild kit £75
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130346972291&ssPageName=STRK:MEWAX:IT
I want £100 for it, take a chance and it may may make a very cheap turbo for someone. Collection prefered so that you can make sure you are happy with it
This is what the turbo looked like fitted
Will come with my V band adaptor
This is what it now looks like:-
XS Power 60 mm external wastegate
Comes with all flanges V band clips and a selection of springs
£90 delivered SOLD
Getrag 6 speed salve cylinders
I dont know how, but after buying all the bits for a manual conversion I am left with 2 slave cylinders (Red and Gold)
Red is TT 6spd
Gold is NA 6spd
I am not sure what they are worth so £30 each £35 posted
TT Jspec Fuel pump
£20 SOLD
BPU Spark plugs
Will add spec and picture these have been used for approx 1 hour. Removed as my mapped recommended lower grade plugs for the high boost I am now running
£20
Assorted TT pipes
Forsale assorted twin turbo pipes as pictures
Offers will split
£40
Garrett braided oil feed for 2jz single
This would suit GT30,35R ect I used it on a T4 hybrid
The adaptor bolts straight to the garret core and the banjo used the standard supra bolt (which I will include).
The turbo fitting has a restrictor to suit ball bearing core, if this is not needed simply drill out.
I have removed as I am now using a Borg Warner which has a completely different oil feed.
There are pictures of it fitted in my thread, below is what you get
£20 collected £25 delivered SOLD
Large Tail replica dump valve
http://www.magix-photos.com/mpfw01/10/B9/E2/A1/E0/90ED11DEA3DB0909D4B78641/C2E59BD090ED11DE99B92C180939C481.jpg
£35 delivered
FSE Power boost valve
Looks brand new and came with a GT4 I bought recently
http://www.magix-photos.com/mpfw01/10/DF/87/52/10/90ED11DE98DE49D1D4B78641/E54B9BC090ED11DEAB38F8AA6BA6A762.jpg
UK Manual ECU
Fully working ran my car last week
£65 delivered
UK Fuel rail
Powder coated black £15 delivered
