colmcork Posted October 26, 2010 Share Posted October 26, 2010 Hi guys, I have searched this (in the limited time I had over lunch) but am still none the wiser. Can I simply swap over the 'open' diff on my '95 j-spec auto TT car with what I am being told is an lsd from a manual TT car circa '96/'97? Unknown if it is off a uk spec or not but am being told that it has an oil cooler on it. I am intending on swapping casings and not just internals. In fact I have been offered the entire rear sub-frame with diff, hubs etc. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted October 26, 2010 Share Posted October 26, 2010 Here is a link to a picture and a brief description of the two types of diff that were used in the Supra. http://www.mkivsupra.net/vbb/showpost.php?p=2777763&postcount=12 Then depending on whether it's a small cased diff you are hoping to fit, which would be good, you can work out if the final ratio of the diff is a good match for the auto box in your car from this: http://www.mkivsupra.net/vbb/showthread.php?t=225050&highlight=calculator Quote Link to comment Share on other sites More sharing options...
Terminator Posted October 26, 2010 Share Posted October 26, 2010 The auto diff has a different ratio from the manual. Use this to see what it will do to your car, http://www.mkivsupra.net/vbb/showthread.php?t=225050 Quote Link to comment Share on other sites More sharing options...
dude Posted October 26, 2010 Share Posted October 26, 2010 The caseing is a diff size if the new diff has an oil cooler it is either a UK spec auto or an early J spec 6 spd, the prop rear section is shorter and theb left drive shaft is different. Quote Link to comment Share on other sites More sharing options...
colmcork Posted October 26, 2010 Author Share Posted October 26, 2010 Thanks for the replies guys:thumbs:. Using the conversion table it seems the gearing will be quite a bit longer and I assume cause my supe to feel slower going up through the 'box. Not too pushed to fit it then if thats going to be the case. I am also thinking this might put slightly more strain on my autobox which I certainly dont want. Do you guys know of anyone off the top of the head who is driving a TT manual L.S.D ( large casing ) with a TT autobox? Both j-spec. I guess if I decide not to use it I should be able to sell the diff on... Quote Link to comment Share on other sites More sharing options...
dude Posted October 26, 2010 Share Posted October 26, 2010 Sorry I miss typed that last reply. If the it has an oil cooler it is either a UK auto or 6 spd not a J spec 6 spd ( diff ratio's) either way its nort a direct bolt in for a j spec auto. Quote Link to comment Share on other sites More sharing options...
Terminator Posted October 26, 2010 Share Posted October 26, 2010 Do you guys know of anyone off the top of the head who is driving a TT manual L.S.D ( large casing ) with a TT autobox? Both j-spec. I guess if I decide not to use it I should be able to sell the diff on... I don't think there will be any, as the ratios are too long, and the auto ECU will not make the best of the box/diff combo. The car will just feel slower. Quote Link to comment Share on other sites More sharing options...
colmcork Posted October 26, 2010 Author Share Posted October 26, 2010 Big thanks for the help guys:). Terminator thanks for the pm. I wonder if I should just go ahead and take this sub frame anyway as it seems the diff is from a UK TT six speed. Surely someone on here will need taking out of a tight spot with one of these at some stage. Quote Link to comment Share on other sites More sharing options...
