Jellybean Posted October 26, 2010 Share Posted October 26, 2010 Is this Correct for doin a Compression Test, some threads contradic one another Halfords Compression Tester tool will do? Disconnect Fuel (EFI Fuse or Ignition Module)? Take out all spark plugs or do one at a time with 5 always remaining? Hot engine? throttle fully open for every cyl? Good Battery Results to be Expected Standard pressure: 1,079 kPa (11.0 kgf/cm2, 156 psi) or more Minimum pressure: 883 kPa (9.0 kgf/cm2, 128 psi) Difference between each cylinder: 98 kPa (1.0 kgf/cm2, 14 psi) or less 189 -190 on most engines that are in tip top condition And each Cylinder is very close to one another no big differences Missing anything? Link to comment Share on other sites More sharing options...
DannoSupra Posted October 26, 2010 Share Posted October 26, 2010 Dont think it makes much of a difference if engine's are hot or cold. But yeah, believe that is correct, well correct procedure, not sure on figures! Link to comment Share on other sites More sharing options...
Jellybean Posted October 26, 2010 Author Share Posted October 26, 2010 (edited) Found this too http://www.turbosupras.com/pdfs/JZA80%20TSRM/EM%20%282JZ-GTE%29.pdf hmm Cam Shaft position Sensor Anybody know how to disconnect the Cam Shaft position Sensor Edited October 26, 2010 by Jellybean (see edit history) Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 26, 2010 Share Posted October 26, 2010 (edited) A compression test is only an indication of cylinder health, a leak-down test will give a more comprehensive result. All plugs out. Throttle fully open. EFI fusees out. Good battery. Make sure you turn the engine over the same number of times for each cylinder, at least 6-8. Edit, there is no need to disconnect the CPS, the fuses will stop fuel entering the cylinder, which is enough. Edited October 26, 2010 by Tricky-Ricky (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted October 26, 2010 Author Share Posted October 26, 2010 A compression test is only an indication of cylinder health, a leak-down test will give a more comprehensive result. All plugs out. Throttle fully open. EFI fusees out. Good battery. Make sure you turn the engine over the same number of times for each cylinder, at least 6-8. Edit, there is no need to disconnect the CPS, the fuses will stop fuel entering the cylinder, which is enough. With all the plugs out, what ablout debris getting into the Cylinder? Link to comment Share on other sites More sharing options...
DannoSupra Posted October 26, 2010 Share Posted October 26, 2010 You should get any going in, at the end of the day, pressure will blow it all out anyways - if its got good compression that is Link to comment Share on other sites More sharing options...
SteveC Posted October 26, 2010 Share Posted October 26, 2010 I always thought that the engine should be hot. A hot engine certainly gives higher readings... Link to comment Share on other sites More sharing options...
Dnk Posted October 26, 2010 Share Posted October 26, 2010 With all the plugs out, what ablout debris getting into the Cylinder? Before you remove the plugs use the airline and blow all round them, then there wont be any debris Link to comment Share on other sites More sharing options...
Guest AlexTC Posted December 7, 2015 Share Posted December 7, 2015 Hello there. i know this is the old post... but ive done my compression test today on my 2jzge and all of them were around 190-180 but number 6 one was 100.... what can be wrong? thank u Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 9, 2015 Share Posted December 9, 2015 Hot, throttle fully open, all plugs out, similar number of cranks per test. But a leakdown test is *FAR* more meaningful and useful. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 9, 2015 Share Posted December 9, 2015 Hello there. i know this is the old post... but ive done my compression test today on my 2jzge and all of them were around 190-180 but number 6 one was 100.... what can be wrong? thank u Valve leakage, ring leakage (with or without a damaged piston or bore), blown head gasket. A leakdown test would tell you just *WHAT* was up, hence why they are much more useful... You might just check the valve clearances haven't closed right up on number 6, which is highly unlikely, so unless that's occurred you might as well start pulling the engine out. Link to comment Share on other sites More sharing options...
Guest AlexTC Posted December 14, 2015 Share Posted December 14, 2015 Thank you guys! Im cleaning the system now and will do the test soon again to see if there is any difference Link to comment Share on other sites More sharing options...
