anyone got 500-550bhp auto
Rob_Mitchell
  • Replies 69
We've run loads of stock auto boxes with an oil cooler at around 550bhp mark and never had one blow up before, and they've been running for years like that. Dont know what happens if you go over that though. Got a couple of long term customers running 1.7 bar on T61's with cams so they must be pushing close to 600bhp and they are fine also. If 550bhp is all you want the stock box will be ok if you ask me.
:yeahthat:
Why the GReddy intake manifold? I'd keep things simple and use the stock manifold.
i did expect someone to come up with that question.
i want to keep under the bonnet a bit minimal and i just love the manifold mate if im honest.
im having loads of fun with my show car and got loads of chrome etc but i might change plans on this build and keep things less in your face with the bling... less is more?
You'll also add around 40hp with the manifold and like you say if you like the decluttered look it works a treat :)
I have just bought a new plenum and I'm doing a little project which us quite interesting, ive bought a veilside replica style plenum and I'm getting it modifeid and machined to house the stock throttle body and all the sensors from the stock plenum so I can run my aem fic.
It will then illuminate any coldstart problems and be as good as stock with hopefully 40-50 bhp more.
Cost wise I will let u know mate, could be a good thing for other people wanting a nice plenum without all the extra problems.
Maybe with a bigger turbo, but with say a T61 I'd be surprised if it'd make much difference.
I agree Nic I think u need a certain size turbo and need to be running high boost levels, however and I understand the stock plenum and manifold are good for 1000bhp+ but if u had the same car running let's say 800bhp and changed the plenum u would defo have a power increase from stock as resistance is less with these performance plenums of up to 20%.
This has to apply to smaller setups running bigger boost level of 1.7+ let's say!
I know a little bit about minimal Rob ;)
mate i know and its yours and jamesy's fault im in this mess :D
this is going to sound so silly but where does all the components which are bolted around the engine go? do i need everything still?
i know i need a tt auto loom :search: but i have no abs which cleans that area up.
is it just a case of getting a turbo kit,intercooler,gearbox cooler,injectors, mapable ecu,throttle body, and im nearly half way there or is there loads more i need.??? list would come in handy :(
Why are you just going for such a low power band then Rob. Bit of a waste of a built engine if you ask me. You'd be fine with a stock TT lump.
im not going na-t no more john, im going to build a single using a tt engine i have.
looking for around 550-600bhp thats more than plenty for me.
I have to agree with hodge, if its down to money and u are limited to power with the stock box your like me!
U could go for a much bigger set up but would need a built box, and we all know there not cheap mate!
Rob here's a list of what u will need to go single, getting a proper kit eliminates allot of the ball ache parts and I would advise it.
Here we go!
Turbo kit
Or
Turbo
Exhaust manifold
Downpipe
Oil & water lines and all adapters for turbo (nightmare job without the kits sometimes)
Induction kit
Air filter
Blow off valve
Turbo hot side intercooler/bov pipe work
That's what I got with my hks turbo kit
Suitable exhaust system
264 in/ex cams
Fmic
Fmic fitting kit
Possible new water hoses
Sports rad
New Anti Freeze
Sandwich plate
Oil cooler engine (large 19-30 row)
Oil cooler gearbox (large 19-30 row)
Oil cooler pas (small/medium 10 row)
Oil lines for all the above and fittings and fitting kits
Oil filter
Oil 5/15w
Fuel rail
Injectors
Resistor pack (if low res)
Inj clips
Fuel regulator
Fuel dampner
Fuel filter
Fuel lines
Fuel pumps
Modified fuel hanger
New coil pack clips/inners
New plugs
Possible new coil packs
Breather system and air filters
Catcher tank
New expansion tank (sports rad)
Relocate battery cables ( greddy plenum)
Throttle body
Ecu?
Mapping sensor?
Egt gauge
Afr gauge
Oil pressure gauge
Oil temp gauge
Gearbox oil temp gauge
Water temp gauge
Fuel pressure gauge
Boost gauge
All fitting kits and senders for above
Wideband controller
Boost controller
I'm sure people will add to the list, but there's an idea rob;)
Edited by wallis (see edit history)
