Rob_Mitchell Posted October 26, 2010 Share Posted October 26, 2010 Hello peeps, just been looking at loads of specs on cars to see what is used ect to achieve 500+bhp on a stock tt autobox. does anyone have a single running 500+ on stock box? if so can you list the spec please? i know everyones specification is different but it will be nice to see different ones listed, for my knowledge of stuff thats needed for my build. many thanks- pics too Link to comment Share on other sites More sharing options...
imi Posted October 26, 2010 Share Posted October 26, 2010 Have a look at the ECU register Link to comment Share on other sites More sharing options...
Abz Posted October 26, 2010 Share Posted October 26, 2010 Rob, I was under the impress anything up to 500bhp is good on the stock box though going close or over 500 bhp it is recommended to go with a built box. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted October 26, 2010 Share Posted October 26, 2010 stock tt autobox. Are you planning on adapting a TT autobox to fit onto your NA for your NA-T project? Link to comment Share on other sites More sharing options...
JamieP Posted October 26, 2010 Share Posted October 26, 2010 Are you planning on adapting a TT autobox to fit onto your NA for your NA-T project? Rob has a built TT engine going in. If i was doing a ST on a stock auto i would go with a phr street kit, keep it simple, 550 injectors, stock TT fpr, single walbro, AEM fic ecu. You are going to have to pick up a tt auto loom and ecu. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted October 26, 2010 Share Posted October 26, 2010 Rob has a built TT engine going in. If i was doing a ST on a stock auto i would go with a phr street kit, keep it simple, 550 injectors, stock TT fpr, single walbro, AEM fic ecu. You are going to have to pick up a tt auto loom and ecu. Awesome Jamie do you know anyone who would be able to fit a TT autobox to an NA? I did some reading on the NA-T forum and a number of guys on thier have a TT autobox on thier NA-T builds. They basically swap parts over from the NA box to the TT box. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted October 26, 2010 Author Share Posted October 26, 2010 Rob has a built TT engine going in. If i was doing a ST on a stock auto i would go with a phr street kit, keep it simple, 550 injectors, stock TT fpr, single walbro, AEM fic ecu. You are going to have to pick up a tt auto loom and ecu. yeah i know and im concerned that im not going to get a loom, sounds very simple which is nice to hear. getting a list together now and buy bits as i go. Link to comment Share on other sites More sharing options...
JamieP Posted October 26, 2010 Share Posted October 26, 2010 Awesome Jamie do you know anyone who would be able to fit a TT autobox to an NA? I did some reading on the NA-T forum and a number of guys on thier have a TT autobox on thier NA-T builds. They basically swap parts over from the NA box to the TT box. Not sure, sounds tricky to me, it would bolt in place i guess, then you would need a TT loom and ecu to run it, and somehow get the na to run on the tt loom i guess. Link to comment Share on other sites More sharing options...
dude Posted October 26, 2010 Share Posted October 26, 2010 If you want to run the TT auto in an NA you will need the loon and ecu, a NA auto will not live behind a single or BPU car for very long. You can make a TT box work with no ECU control by fitting a NA valve body, that way you have the best of both worlds, you can run an auto without the ecu controling anything and still have the 4 clutch packs of the TT box, you can also get an uprated 2nd gear sprag as this is the weak part of the box. Link to comment Share on other sites More sharing options...
Nic Posted October 26, 2010 Share Posted October 26, 2010 does anyone have a single running 500+ on stock box? if so can you list the spec please? Not an auto, but my garage lists full spec of mine, power 500-550+hp depending how much boost you run. I don't know how much the auto box can take, but I'm sure there'll be a few on here with experience. In terms of kits for around that power there are a few good choices, the PHR street kit as Jamie mentioned - good for upwards of 500hp, the smaller PHR and BL kits with tubular manifold, capable of around 550hp. Or my own personal choice would be an HKS kit with Garrett GT35R. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted October 26, 2010 Share Posted October 26, 2010 Not sure, sounds tricky to me, it would bolt in place i guess, then you would need a TT loom and ecu to run it, and somehow get the na to run on the tt loom i guess. It does sound tricky, guess i'll just wait and see what kind of results Paul gets with his NA-T setup on his Auto test car. The TT Autobox just gives the future proof of being able to go for bigger power. I think Bootlogic sell a built NA Autobox, that could be the simpler way of running higher power on an auto NA-T setup. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted October 26, 2010 Author Share Posted October 26, 2010 thanks nic good info mate, i thought you would mention the hks range lol. i think a small setup is ideal at the moment and then i have the choice to upgrade for more power later on, which i never had this choice with the na-t route. im going to look into the PHR street kit, im going to need a cooler on the gearbox if not 2 but im sure it can handle 500bhp easy. Link to comment Share on other sites More sharing options...
Jamesy Posted October 26, 2010 Share Posted October 26, 2010 I think Stonkin has this sort of power thro a stock autobox mate Link to comment Share on other sites More sharing options...
SamuraiFlash Posted October 26, 2010 Share Posted October 26, 2010 You can make a TT box work with no ECU control by fitting a NA valve body, that way you have the best of both worlds, you can run an auto without the ecu controling anything and still have the 4 clutch packs of the TT box, you can also get an uprated 2nd gear sprag as this is the weak part of the box. Dude, this sounds promising So is this a job you will be willing to take on? What parts would you require apart from the TT Autobox, Uprated 2nd gear sprag? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted October 26, 2010 Author Share Posted October 26, 2010 thanks jamesy. Link to comment Share on other sites More sharing options...
JamieP Posted October 26, 2010 Share Posted October 26, 2010 Have a look at Lui's garage Rob, he is on a phr street kit with stock TT autobox. Link to comment Share on other sites More sharing options...
dude Posted October 26, 2010 Share Posted October 26, 2010 Dude, this sounds promising So is this a job you will be willing to take on? What parts would you require apart from the TT Autobox, Uprated 2nd gear sprag? Depends what power you want the box to take dude, the 2nd gear sprag is always the weak point, you need a TT and an NA box to do this and make one that will fit, if you swap looms its not too hard to just chuck in a TT box, by the time you buy a new BL box and a precision converter you may as well go 6 spd. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted October 26, 2010 Author Share Posted October 26, 2010 Have a look at Lui's garage Rob, he is on a phr street kit with stock TT autobox. yeah read through it all last night, seen it at shows a few times its a nice tidy build. that phr kit is very good value for money, be an import charge though wont there?? Link to comment Share on other sites More sharing options...
wallis Posted October 26, 2010 Share Posted October 26, 2010 This is the same power I'm aiming for, and going to be running a stock auto, until it dies. I'm going to actually see what it can take torque wise, it's not the bhp which is the problem mate! I bought another one for £100 so will swap if the other one goes, cheap fix really. I'm running a hks gt30r and it will have almost the same amount of torque as bhp, my set ups changed alot as I went along! Good news your starting to organise your single build, best of luck Link to comment Share on other sites More sharing options...
Nodalmighty Posted October 26, 2010 Share Posted October 26, 2010 (edited) You should be able to run the additional Line Pressure and Accumulator solenoids of a TT auto with an AVR and a few FET's for about £20. I'll be putting a TT auto in my Passat and making a little box to manually control it and talk to the Syvecs. I have a MK3 ECT ECU for doing the day to day auto control as it's a stand alone unit. Need to get an oscilloscope on the accumulator to see what PWM frequencies it's using and when. Edited October 26, 2010 by Nodalmighty (see edit history) Link to comment Share on other sites More sharing options...
SamuraiFlash Posted October 26, 2010 Share Posted October 26, 2010 Depends what power you want the box to take dude, the 2nd gear sprag is always the weak point, you need a TT and an NA box to do this and make one that will fit, if you swap looms its not too hard to just chuck in a TT box, by the time you buy a new BL box and a precision converter you may as well go 6 spd. I'll initially be running the car between 330-325hp, then go upto 380-400hp. If this hybrid box can handle this then i'd be over the moon. Link to comment Share on other sites More sharing options...
hodge Posted October 26, 2010 Share Posted October 26, 2010 I ran about 500hp on a stock autobox on my blue car Rob. It never missed beat either. Have a look in my garage for the spec mate. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted October 26, 2010 Author Share Posted October 26, 2010 This is the same power I'm aiming for, and going to be running a stock auto, until it dies. I'm going to actually see what it can take torque wise, it's not the bhp which is the problem mate! I bought another one for £100 so will swap if the other one goes, cheap fix really. I'm running a hks gt30r and it will have almost the same amount of torque as bhp, my set ups changed alot as I went along! Good news your starting to organise your single build, best of luck thanks mate, although i own a garage this sort of work is fresh to me and im reading lots on what to get for the build. abbreviations are hard to follow but i think im getting there lol if i can get everything sourced it will then have a trip down to srd Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted October 26, 2010 Author Share Posted October 26, 2010 I ran about 500hp on a stock autobox on my blue car Rob. It never missed beat either. Have a look in my garage for the spec mate. thanks john, wow nice spec.... what throttle body did you use? Q45? Link to comment Share on other sites More sharing options...
