mikeyh Posted October 25, 2010 Share Posted October 25, 2010 if possible will i beable to borrow 1 to see whats exactly wrong with my supra i know you need a compressor to use it but i have one at work so that wont be a problem, i just want to get a ruff idea of damage etc to see if its worth me repairing or breaking mine:search: Link to comment Share on other sites More sharing options...
Lude Posted October 25, 2010 Share Posted October 25, 2010 what is one? asume you dont mean a boost leak tester! Link to comment Share on other sites More sharing options...
j_jza80 Posted October 25, 2010 Share Posted October 25, 2010 what is one? asume you dont mean a boost leak tester! For testing compression in the cylinders Link to comment Share on other sites More sharing options...
Scott Posted October 25, 2010 Share Posted October 25, 2010 Quite a few of us will have compression testers but leak down testers might be harder to get your mits on. Is the car dead? Would taking it to a local garage not be an option? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 25, 2010 Share Posted October 25, 2010 A leak-down tester consists of two gauges linked in such a way as to feed a constant pressure to a cylinder, and monitor to lost pressure differential, which gives a pretty good indication of the state of the cylinder/ring seal and the valve/seat seal. Far better than just a compression test, as it gives a constant loss figure, rather than a accumulation of cylinder pumping capability. Oh! and its not too hard to make one if you have a couple of decent gauges lying around;) Link to comment Share on other sites More sharing options...
Dnk Posted October 25, 2010 Share Posted October 25, 2010 A leak down test pressurises each cylinder and gives you a percentage that the cylinder is leaking by, also lets you diagnose if the air is escaping via the inlet valves, exhaust valves or piston rings As above Link to comment Share on other sites More sharing options...
mikeyh Posted October 25, 2010 Author Share Posted October 25, 2010 A leak-down tester consists of two gauges linked in such a way as to feed a constant pressure to a cylinder, and monitor to lost pressure differential, which gives a pretty good indication of the state of the cylinder/ring seal and the valve/seat seal. Far better than just a compression test, as it gives a constant loss figure, rather than a accumulation of cylinder pumping capability. Oh! and its not too hard to make one if you have a couple of decent gauges lying around;) what is needed to make 1 do you have a guide to making 1 or have you done it yourself Link to comment Share on other sites More sharing options...
mikeyh Posted October 25, 2010 Author Share Posted October 25, 2010 Quite a few of us will have compression testers but leak down testers might be harder to get your mits on. Is the car dead? Would taking it to a local garage not be an option? ive got a compression tester but it doesn't tell you the cause of the problem it just shows that there is a problem:search: Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted October 25, 2010 Share Posted October 25, 2010 you can also hire them mate or buy http://cgi.ebay.co.uk/ENGINE-CYLINDER-LEAKDOWN-LEAKAGE-TESTER-BUY-HIRE-/320554086182?pt=UK_Measuring_Tools_Levels&hash=item4aa2832f26 Link to comment Share on other sites More sharing options...
JustGav Posted October 25, 2010 Share Posted October 25, 2010 http://www.motorcycleproject.com/motorcycle/text/leakdown.html Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 25, 2010 Share Posted October 25, 2010 what is needed to make 1 do you have a guide to making 1 or have you done it yourself Not what i used but it gives you the idea, http://www.hondatuningmagazine.com/tech/htup_0812_diy_leak_down_testing/index.html Link to comment Share on other sites More sharing options...
mikeyh Posted October 25, 2010 Author Share Posted October 25, 2010 you can also hire them mate or buy http://cgi.ebay.co.uk/ENGINE-CYLINDER-LEAKDOWN-LEAKAGE-TESTER-BUY-HIRE-/320554086182?pt=UK_Measuring_Tools_Levels&hash=item4aa2832f26 hireing 1 might be the easiest way do you know of any traders etc? Link to comment Share on other sites More sharing options...
