does anybody have a leakdown tester
mikeyh
if possible will i beable to borrow 1 to see whats exactly wrong with my supra i know you need a compressor to use it but i have one at work so that wont be a problem,
i just want to get a ruff idea of damage etc to see if its worth me repairing or breaking mine:search:
A leak-down tester consists of two gauges linked in such a way as to feed a constant pressure to a cylinder, and monitor to lost pressure differential, which gives a pretty good indication of the state of the cylinder/ring seal and the valve/seat seal.
Far better than just a compression test, as it gives a constant loss figure, rather than a accumulation of cylinder pumping capability.
Oh! and its not too hard to make one if you have a couple of decent gauges lying around;)
what is needed to make 1 do you have a guide to making 1 or have you done it yourself
Quite a few of us will have compression testers but leak down testers might be harder to get your mits on.
Is the car dead? Would taking it to a local garage not be an option?
ive got a compression tester but it doesn't tell you the cause of the problem it just shows that there is a problem:search:
