dude Posted December 24, 2002 Share Posted December 24, 2002 Hey guys ive got a J-spec TT how many cats does it have on it , the first couple are obvious but ive got a thing that looks like a cherry bomb near the back box does this have to go aswell. John:stupid: Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted December 24, 2002 Share Posted December 24, 2002 You've only got two but that's two too many! Quote Link to comment Share on other sites More sharing options...
Alex Posted December 24, 2002 Share Posted December 24, 2002 Its the two lumps near the turbo end. Quote Link to comment Share on other sites More sharing options...
Darren Posted December 24, 2002 Share Posted December 24, 2002 The cherry bomb is the silencer me thinks...As Matt said loose the CATS or atleast the 2nd one! Darren Quote Link to comment Share on other sites More sharing options...
dude Posted December 24, 2002 Author Share Posted December 24, 2002 these arent the sort of pussy i like they will have to go , thanks guys consider them history. John:flame Dev Quote Link to comment Share on other sites More sharing options...
Darren Posted December 24, 2002 Share Posted December 24, 2002 Just make sure you are not overboosting without them! ie no more than 1.2bar John!! Darren Quote Link to comment Share on other sites More sharing options...
dude Posted December 24, 2002 Author Share Posted December 24, 2002 is 1.2 bar the limit because of detonation or turbo life , what can be done so the turbos will handle more boost ???? John:stupid: Quote Link to comment Share on other sites More sharing options...
Darren Posted December 24, 2002 Share Posted December 24, 2002 John, Although not a technician, I think the answer to your question is both! I want to go higher on mine but I think you are talking hybrid turbos, improved fueling, altered timing (New ECU maybe)etc to achieve this...... Any techies please feel free to help out!! Darren Quote Link to comment Share on other sites More sharing options...
dude Posted December 24, 2002 Author Share Posted December 24, 2002 Darren thats my masterplan, uk injectors, apexi power c ECU, hy-brids and water injection , any comments from the techies more than welcome. John:stupid: Quote Link to comment Share on other sites More sharing options...
GavinL Posted December 24, 2002 Share Posted December 24, 2002 Originally posted by dudersvr is 1.2 bar the limit because of detonation or turbo life , what can be done so the turbos will handle more boost ???? John:stupid: Assuming j-spec turbos. both and realistically nothing bar upgrade to hybrid. Quote Link to comment Share on other sites More sharing options...
dude Posted December 24, 2002 Author Share Posted December 24, 2002 Gavin what sort of boost can hybrids run ????? John:stupid: Quote Link to comment Share on other sites More sharing options...
Alex Posted December 24, 2002 Share Posted December 24, 2002 If you don't mind I'll butt in Hybrids can be made to handle 2bar maybe more.... A better question is what boost can I run on hybrids with a stock manifold. answer = your EGT's will tell you but I would guess 1.8bar would be the max on a stock manifold - assuming you run a full decat, WI and an FMIC. Hybrids come in (I believe) 4 different states of tune. From Mild to Wild. I would assume that these include different A/R's to affect lag and peak power output. EDIT - Fuelling wise the UK system with a Walbro Fuel Pump can handle 1.6bar. You might need a bigger pump and adjustable fuel pressure regulator for higher boost. Quote Link to comment Share on other sites More sharing options...
dude Posted December 24, 2002 Author Share Posted December 24, 2002 Thanks Alex Does that walboro pump go in the tank or is it external , i take it the standard uk pump will not be up to this?????. How much performance diff between 1.2 and 1.8 bar ?????? Quote Link to comment Share on other sites More sharing options...
dude Posted December 24, 2002 Author Share Posted December 24, 2002 one more q. chaps . Do any of the electronic gizmos feature a detonation sensor and have the capability of pulling off (ohh errr) your boost John:stupid: Quote Link to comment Share on other sites More sharing options...
GavinL Posted December 24, 2002 Share Posted December 24, 2002 Originally posted by dudersvr one more q. chaps . Do any of the electronic gizmos feature a detonation sensor and have the capability of pulling off (ohh errr) your boost John:stupid: No. Quote Link to comment Share on other sites More sharing options...
GavinL Posted December 24, 2002 Share Posted December 24, 2002 I think we need a dyno day for hybrid cars next year. There are at least two suppliers of hybrids in the UK and I don't doubt a fair few more. Leon currently supplies 3 levels of hybrid plus custom specs so it becomes tricky to compare within that range without trying to compare with other suppliers. Quote Link to comment Share on other sites More sharing options...
Alex Posted December 24, 2002 Share Posted December 24, 2002 Walbro, Bosch and http://www.fluidcontrol.net all do in tank pumps. To get the system right and avoid detonation you need to be able to overfuel at WOT (wide open throttle). http://www.TDI-PLC.com can supply there own pump - I assume it a specific model from one of the better know pump makers. They have a flow chart of various pumps which you can see here http://www.tdi-plc.com/suprafuelpumpdata.html ****************** Can anyone tell me what fuel pressure the j-spec and UK spec run? Quote Link to comment Share on other sites More sharing options...
eyefi Posted December 29, 2002 Share Posted December 29, 2002 john, the stock ecu will retard ignition timing on knock detection and the aem ecu (and possibly others) includes some controls for knock detection. dont forget u only want this as a last chance safety measure not as a method of tuning (u probably already know this ) Quote Link to comment Share on other sites More sharing options...
GavinL Posted December 29, 2002 Share Posted December 29, 2002 Originally posted by Alex Holdroyd Can anyone tell me what fuel pressure the j-spec and UK spec run? 36psi I beleive. Apparently this is fairly universal as this is the pressure fuel injectors are rated at. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted December 30, 2002 Share Posted December 30, 2002 Originally posted by GavinL 36psi I beleive. That's only at idle (book figure is 33 - 40psi) once your boosting that increases to, if i remember rightly, 30+psi above your boost pressure. Quote Link to comment Share on other sites More sharing options...
