Oil in 6th piston - help pls
PDowdy
This whole statement "About 3 months ago my radiator blew in my 95 j-spec TT auto. Never got to the bottom of why but replaced with a new alloy one and relocated into a dedicated oil cooler. Never had any more heat problems before or after - but when it blew the engine temp was off the scale for about 5-10mins"
Beggar's belief! you had a SERIOUS overheat, and all you did was chuck a new rad at it and fitted an oil cooler, and continue driving, without a thorough investigation? The very fact that it overheated in the first place, indicates a problem, and likely head gasket failure, presuming that you check the fluid levels frequently?
Sorry if my comment is not commiserative enough, but you really need to develop a more sympathetic attitude to your engine if you expect to benefit form its performance.
From the sounds of it you are looking at a full rebuild, as you have probably been suffering from water in the oil for the last three months of driving, and so will have undoubtedly caused bearing damage.
Edited by Tricky-Ricky (see edit history)
I would deffinatly get the head checked and just fit an new H/G then do a complete engine flush both water and oil then refill with brand new liquids.
Run until its normal running temp and check both water and oil, but first make sure the top hose isnt about to burst before you remove the rad cap.
If your mechanicly minded then do it yourself or get ripped off by garage fee's that still dont fix the problem.
Has no one realised that if there was enough water in the cylinder to have to have to drain out and it was still spitting out when turning over then the engine would have hydrauliced and prob thrown a rod if it did not do that cylinder pressure would have blown the rad apart.
The guys mate is the mechanic.
i see what you mean but this is what we couldnt understand, the crack in the h/g is so slight it couldnt get the volume of water back through - the car has run fine since the overheating incident - since the old rad had cracked and was replaced with the ally one no water went in the oil no oil in the water and its ran for months with no leaks - then this hapened:(
the cyl was full of water when i took the plug out it flooded out - i cant believe that it had been running like that without hydraulicing the engine - the chances of it parking up on the exhaust stroke every time seem very unlikely and as said the h/g crack was so slight i was expecting damage in the head or block but we cant see any - before we investigated it the car drove spot on other than the vibrations on idle:(
