Guest jordy114 Posted October 23, 2010 Share Posted October 23, 2010 hi after a bit of advice just been out in the supra ,and noticed the heater not blowing hot air when on max temp,checked the hoses going into the matrix both piping hot,,so dont think matrix is blocked,engine temp is at normal,if you turn temp dial to min blows cold back to max on temp dial just slightly warm,,also noticed,heater top hose to rad mad hot ,bottom hose,warm,,need to get it sorted as jack frost is on his way,,,dont do cold,,lol could the temp controller dial be faulty or is there any other common faults Quote Link to comment Share on other sites More sharing options...
SteveC Posted October 23, 2010 Share Posted October 23, 2010 Have a quick look at my post here first and then take if from there. It could be just a two minute fix - with a bit of luck. Quote Link to comment Share on other sites More sharing options...
Guest jordy114 Posted October 24, 2010 Share Posted October 24, 2010 cheers steve i will have a look at that sounds like it could be that ,i will let you know how i go on Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 24, 2010 Share Posted October 24, 2010 Good luck. Has it ever had the matrix changed or the heater hoses ? check their on the right way round, mine had been fitted back to front which causes the exact same problem you have. Quote Link to comment Share on other sites More sharing options...
