Air Compressor
SupraJames
Am selling my air compressor as not really using it all that much. It is an Ingersoll Rand older model but still in great quality and is ideal for running air tools or maybe a spray gun. Its on a 240v plug and standard female air line output. Not sure on tank capacity but it is a large compressor.
£200 and must be collected due to size and weight.
Thanks
I can not find any CFM rating on the compressor at all, checked the Ingersoll Rand website and cant see any CFM rating for any of their new products either :(
The figures on the plate by the gauges I will assume as just for the Air Tank and read Test Press 16.5 Bar, Des Press 11 Bar
It is an Ingersoll Rand Model EN3C20B
Looking at the specs of a 1.5 Kw Motor with approx 100L Tank and comparing it to the new models I would guess the CFM at around 8-9 but as I said that would be a very rough guess.
are you sure...maybe its more then as it painted many cars,runs d/a,air ratchets etc etc and never goes below half tank...whatever it is it must be at least 12 cfm stick it on ebay as mine was 300 s/hand...that will sell easily...
A d/a will not run properly for more than a couple of mins on 12cfm without the motor kicking to try and keep up. I have an extra tank and it just can't keep up. Same sort of problem with the airfed mask and gun. I may still come and look at this though if that's ok as I have an idea.
