sim1987 Posted October 22, 2010 Share Posted October 22, 2010 saw this on ebay when i was scouting for bits as you do, was wanting a second oppinion: http://cgi.ebay.co.uk/RAM-AIR-UNIVERSAL-AIR-INDUCTION-KIT-25-PSI-BOOST-!_W0QQitemZ150503270874QQcmdZViewItem?rvr_id=157035727967&rvr_id=157035727967&cguid=56d04cc112a0a0e205336143fef407f6 Link to comment Share on other sites More sharing options...
Scott Posted October 22, 2010 Share Posted October 22, 2010 In a word yes, it will work. It's useless though. Too crude. Link to comment Share on other sites More sharing options...
ellis Posted October 22, 2010 Share Posted October 22, 2010 Fit in minutes - no expertise required??!! Sounds like a recipe for a rebuild. Isn't this just the same as NoS? Link to comment Share on other sites More sharing options...
jevansio Posted October 22, 2010 Share Posted October 22, 2010 25 PSI for 0.000000001 second Link to comment Share on other sites More sharing options...
Scott Posted October 22, 2010 Share Posted October 22, 2010 Fit in minutes - no expertise required??!! Sounds like a recipe for a rebuild. Isn't this just the same as NoS? Much more dangerous. NoS at least cools the intake charge and raises the octane. This thing works the same as a turbo..... without any management. Fire 25PSi into any car and it WILL go bang if you don't control it and fuel it properly. Link to comment Share on other sites More sharing options...
Scott Posted October 22, 2010 Share Posted October 22, 2010 25 PSI for 0.000000001 second The tank should make it last a little longer but I wouldn't expect a LOT from it. Link to comment Share on other sites More sharing options...
jevansio Posted October 22, 2010 Share Posted October 22, 2010 The tank should make it last a little longer but I wouldn't expect a LOT from it. Sorry yeah, 0.0000000002 second Link to comment Share on other sites More sharing options...
nasoup Posted October 22, 2010 Share Posted October 22, 2010 Sorry yeah, 0.0000000002 second He said a little longer not double! Link to comment Share on other sites More sharing options...
sim1987 Posted October 22, 2010 Author Share Posted October 22, 2010 just as i thought a load of sh*t just a good way of blowing an engine. Link to comment Share on other sites More sharing options...
edge Posted October 22, 2010 Share Posted October 22, 2010 25psi @ 1 cfm A real turbo is able to move alot of air. This would be like fitting the worlds smallest turbo and all of its boost pressure coming out of a tiny nozzle. A tiny diesel turbo running 2bar for example would not produce the same amount as something like a T88 at the same pressure. I would imagine if fitted to a car with an electric supercharger, fuel boost valve and a chip then nothing would touch such a beast. Link to comment Share on other sites More sharing options...
Scott Posted October 22, 2010 Share Posted October 22, 2010 i would imagine if fitted to a car with an electric supercharger, fuel boost valve and a chip then nothing would touch such a beast. Link to comment Share on other sites More sharing options...
Scott Posted October 22, 2010 Share Posted October 22, 2010 Sorry yeah, 0.0000000002 second He said a little longer not double! Yeah Jay, no need to go nuts mate lol. Link to comment Share on other sites More sharing options...
jevansio Posted October 22, 2010 Share Posted October 22, 2010 Still, be enough to give an edge over an NA Link to comment Share on other sites More sharing options...
sim1987 Posted October 22, 2010 Author Share Posted October 22, 2010 Still, be enough to give an edge over an NA untill you take it to far and your engine goes bang. Link to comment Share on other sites More sharing options...
Scott Posted October 22, 2010 Share Posted October 22, 2010 Still, be enough to give an edge over an NA Mate, my baby Iris dropped one in the focus. The potential to kinetic transfer was enough to give the edge over an N/A. Maybe I should market Heinz on ebay as a performance mod. Link to comment Share on other sites More sharing options...
Scott Posted October 22, 2010 Share Posted October 22, 2010 untill you take it to far and your engine goes bang. To be honest. Money no object it could be an interesting bit of fun. It would all swing on how good the regulator was in relation to the revs of the engine. The theory is sound enough but it would take FAR more to get it working efficiently and safely than a set of A4 instructions, a compressor, a tank and a regulator. Link to comment Share on other sites More sharing options...
sim1987 Posted October 22, 2010 Author Share Posted October 22, 2010 might just get one and fit it to the honda see what happens, start the boost of small and see what works best. Link to comment Share on other sites More sharing options...
Scott Posted October 22, 2010 Share Posted October 22, 2010 might just get one and fit it to the honda see what happens, start the boost of small and see what works best. If you have that money to burn then go for it. Give me a shout, wouldn't mind playing around with it. The thing is, it would need mapped for the extra air volume going in. Without fuel the mix would get too lean, depending how far the boost pressure goes at the manifold sold. You would only, safely, get the same amount of power as you would from a remap. Potentially you could get more but the mixture would lean out too much and BANG. By the time you add up all the costs of the supporting mods it really isn't worth it. Link to comment Share on other sites More sharing options...
kill1308 Posted October 22, 2010 Share Posted October 22, 2010 Sorry yeah, 0.0000000002 second From the look of it, it keeps the canister pressurised at a minimum of 145psi with an on-board compressor. So you should get at least 0.0000000004 seconds of boost I'd have thought Link to comment Share on other sites More sharing options...
sim1987 Posted October 22, 2010 Author Share Posted October 22, 2010 what else you think you would need and how much we talking about. Link to comment Share on other sites More sharing options...
Scott Posted October 22, 2010 Share Posted October 22, 2010 what else you think you would need and how much we talking about. Piggyback ECU Possibly Injectors although it would depend on the headroom on your stock ones. I don't think they would be pushed. Custom mapping (Unknown kit, development mapping would take days) Fitting if it's required. The mapping is your really big hit. You would need a day minimum just to see what the thing does. No doubt the control system would be full of shite and something bespoke would need to be made up. Best case scenario I would guess about 2k including the kit. You have a potential gain of sweet FA, or worst case scenario a fubarred engine with no comeback. Link to comment Share on other sites More sharing options...
sim1987 Posted October 22, 2010 Author Share Posted October 22, 2010 Best case scenario I would guess about 2k including the kit. You have a potential gain of sweet FA, or worst case scenario a fubarred engine with no comeback. think al just buy a turbo kit:D Link to comment Share on other sites More sharing options...
Scott Posted October 22, 2010 Share Posted October 22, 2010 Best case scenario I would guess about 2k including the kit. You have a potential gain of sweet FA, or worst case scenario a fubarred engine with no comeback. think al just buy a turbo kit:D Now you're making sense. Better yet, sell up and buy a TT Link to comment Share on other sites More sharing options...
sim1987 Posted October 22, 2010 Author Share Posted October 22, 2010 buying the tt takes the fun out of building one. Link to comment Share on other sites More sharing options...
Scott Posted October 22, 2010 Share Posted October 22, 2010 Now you're making sense. Better yet, sell up and buy a TT buying the tt takes the fun out of building one. Tell you what, go down the line of building a N/A-T and then tell me that Link to comment Share on other sites More sharing options...
