Caliper refurb guide
Sandy-m2
Ok folks so my car failed its MOT today and I need to refurb a caliper, went to Mr T and ordered the kit but I was wondering if anyone can do a how too.
Theres lots of chat about it on here solving the problem but no one has actually mentioned how to do it.... is it so simple that i dont need told or is there good instuctions with the refurb kit?
Any help, as always, is much appreciated
Thanks
Sandy
When I did mine I had the whole caliper off the car, then used compressed air to get the pistons out. They will both ( j-spec front ) slide out 95% of the way, then one will let go and come out like a bullit:d.( Be very carefull of the fingers here, or in my case the two dogs sleeping within the firing range:taped:). You then need to pull the other one out using some sort of pliers. Hope this helps.
Ok so i cant get a compressor, is this something i should leave to a garage then?
If you're not confident of doing it yourself then don't. :)
You don't normally get any instuctions with a refurb kit.
You'll need to inspect the pistons/bores too and the sliders if you have the smaller brakes. I had to replaces 2 pistons on mine as they were pitted.
I used a compressor to push out the pistons, use a small block of wood to prevent them shooting out and causing some damage.
