Full heater box fromt behind dash 1997
spiderpigcity
its about 3 hours work to get that out
i would say if you do it proplery without damaging loom clips and and not scratching plastics i would say you need 2 days with air tools. maybe 3 without that is to remove and re install
just an example
remove front seats
remove steering wheel and airbag
remove passenger airbag
remove kick plates and all plastic trims
unplug all plugs from both sides of foot wells
remove all dash panels
remove stereo and all bumf behind and below it
remove steering column and let it drop down onto the floor
remove bolts holding dash in , some sneeky ones so if it doesnt come out its cos theres a sneeky bolt somwhere
remove all the wiring looms or you will never get the dash out as the looms are attached to the frame and the dash (bummer)
lift dash out carefully
remove dash mounting frame (big thing that runs across whole car
go into engine bay and remove bolts hold aircon pipes to bulk head ( you might have to remove some other stuff to get to it first)
remove pipes (de pressurize system first)
remove the 2 10mm bolts that are next to the air con pipes
go back into car and remove all the 10 mm bolts holding the heater box assembly in
remove the 2 plugs on passenger side
the whole lot should come out
Now try and figure out how it all goes back together
anyone who can do it in a day is a genius
I can't see that taking days. I've had everything inside my car, other than the dash, out and it only took me about an hour, maybe less. Removing the dash would be another hour or 2 as described above.
Good job you aren't charging hourly :D
I don't think I've ever seen a heater assembly up for sale. Is that the going rate? Seems quite a good price for a core component like that :)
trouble is mate im 290lbs in the off season and cant get my arms through the gaps, so it makes things a lot slower than if i was a "peter pipe cleaner."
should be about 250 but you lot would winge so i made it 150. :eyebrows:
probably a good £1000 plus from toyota
  • 4 weeks later...
  • 1 month later...
  • 2 months later...
  • 1 month later...
