Matt H Posted October 21, 2010 Share Posted October 21, 2010 Not sure if anyone is interested but I have the above available. They have only done about 200miles if that since I changed them out to put some Iridium grade 8 plugs in. They have been gapped by a professional so no need to worry about that. Might make a nice cheap serviceable item for someone. Say £10 posted. Can take pics of them if necessary. Link to comment Share on other sites More sharing options...
Havard Posted October 21, 2010 Share Posted October 21, 2010 What are they made of Matt? I am not sure what Jurgen would ahve fitted to mine but I was going to go Iridiums myself as I did with the NA..!! H. Link to comment Share on other sites More sharing options...
Matt H Posted October 21, 2010 Author Share Posted October 21, 2010 What are they made of Matt? I am not sure what Jurgen would ahve fitted to mine but I was going to go Iridiums myself as I did with the NA..!! H. They are just standard, not Iridium. Good for anything up to BPU+ I reckon. Link to comment Share on other sites More sharing options...
T2 MSW Posted October 21, 2010 Share Posted October 21, 2010 What are they made of Matt? I am not sure what Jurgen would ahve fitted to mine but I was going to go Iridiums myself as I did with the NA..!! H. If they have been gapped they are not iridiums fella Link to comment Share on other sites More sharing options...
Matt H Posted October 21, 2010 Author Share Posted October 21, 2010 If they have been gapped they are not iridiums fella You can gap Iridum plugs... Link to comment Share on other sites More sharing options...
T2 MSW Posted October 21, 2010 Share Posted October 21, 2010 You can gap Iridum plugs... No you can't, its why all the iridiums in the FAQ section state to leave the gap alone and the manufactures tell you not to do it. You can damage the elctrode which is why its not recommended. http://www.densoiridium.com/faq.php Link to comment Share on other sites More sharing options...
Matt H Posted October 21, 2010 Author Share Posted October 21, 2010 No you can't, its why all the iridiums in the FAQ section state to leave the gap alone and the manufactures tell you not to do it. You can damage the elctrode which is why its not recommended. http://www.densoiridium.com/faq.php Even your qouted website says you can! It just says it's not usually necessary and you have to be careful! Q.Do I need to set the gap? A. Generally, no. The DENSO Iridium Power plug comes pre-set with a protective sleeve over the firing end, to protect the gap from accidental alteration. DENSO Iridium Power’s ultra-efficient firing power compensates for normally recommended gap settings that are smaller than the pre-set value. In the cases of vehicle modifications (nitrous, turbo-chargers, super-chargers, high power ignition systems, etc.), some adjustments may be desired. Or, if you prefer to remain consistent with factory specifications, you may adjust. However, please be careful not to place any stress on the fine center electrode during adjustment. You could accidentally break off the very hard, and therefore brittle, tip. Link to comment Share on other sites More sharing options...
T2 MSW Posted October 21, 2010 Share Posted October 21, 2010 Gapping a £3 plug fine For a set of £50-80 plugs is it worth the risk?? IMO deffo not. Link to comment Share on other sites More sharing options...
Havard Posted October 21, 2010 Share Posted October 21, 2010 If they have been gapped they are not iridiums fella I didn't think they were mate. If they were platinums I may have taken them in the short term but I reckon the ones Jurgen fitted will get me till the summer.!! H. Link to comment Share on other sites More sharing options...
