Digsy Posted October 21, 2010 Share Posted October 21, 2010 Like a few other people on here, my aerotop roof leaks from where the seal around the front glass and A-pillars meets the side glass and roof rail. Sometimes it leaks on the left, sometimes on the right, sometimes both, sometimes not at all. Anyway, I'm fed up with having bin liners on my seatsm but I also know that at least one person on here has replaced all the seals only to find that the roof still leaked. Has anyone successfully cured a leaky aerotop roof? Link to comment Share on other sites More sharing options...
Matt H Posted October 21, 2010 Share Posted October 21, 2010 I had a minor leak on the drivers side a while back. I adjusted the height at which my door window sits and it sorted it out. Have you tried this? Obviously a cheaper solution before trying new seals. Link to comment Share on other sites More sharing options...
Ark Posted October 21, 2010 Share Posted October 21, 2010 Sounds like a bit of a shit suggestion, but are you fitting the roof when parked on a level surface? My old aerotop would get leaks if the roof was fitted when parked on uneven ground. If I fitted it when on a properly flat surface, it was fine. Link to comment Share on other sites More sharing options...
AndrewOW Posted October 21, 2010 Share Posted October 21, 2010 My roof leaks on the drivers side, only in really persistent rain, where I put some silicone grease on the 'joins', and the seams there, and that seems to do the trick for a while. I had previously replaced the passenger roof seal, and that stopped the leaking altogether, so renewing them does appear to work. Link to comment Share on other sites More sharing options...
jackso11 Posted October 21, 2010 Share Posted October 21, 2010 I got some clear silicone and lifted the old seal up, cleaned underneath and put clear sealent under it, then stuck it down fixed. I have also bought a full new set of seals that I am not fitting until after my respray. Link to comment Share on other sites More sharing options...
Digsy Posted October 21, 2010 Author Share Posted October 21, 2010 Its leaked since the day I bought it. I've done the silicone grease thing, and I always make sure the car is level when I put the roof in. The seals seem to fit together perfectly, but somehow the water finds a way in. I hadn't thought of adjusting the window height. I'll have to have another look at how the water comes in and see if it looks like that will help. Is adjusting the window height a simple job? Link to comment Share on other sites More sharing options...
Matt H Posted October 21, 2010 Share Posted October 21, 2010 Is adjusting the window height a simple job? yeah, quite straight forward. Get the door card off and there's two bolts holding the window to the winder. There's scope to adjust and set it slightly higher. Might create the seal you need. Link to comment Share on other sites More sharing options...
Digsy Posted October 21, 2010 Author Share Posted October 21, 2010 Hmmm. I'll check that out. Cheers! Link to comment Share on other sites More sharing options...
The Raven Posted October 21, 2010 Share Posted October 21, 2010 Id never buy an aero wahhh wahhh wahh....Not in the uk.....Wahh wahh wahh. I thought id get in there before someone else does. Mine leaks since i pulled someones DIY repair off. I should fix it i plan in replacing the DIY repair with tiger seal. Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 21, 2010 Share Posted October 21, 2010 Corvette T tops always did this when they got elderly and the only long term fix was all new seals. All that body flex will soon have it leaking again though ... Link to comment Share on other sites More sharing options...
Matt H Posted October 21, 2010 Share Posted October 21, 2010 Corvette T tops always did this when they got elderly and the only long term fix was all new seals. All that body flex will soon have it leaking again though ... I wondered when the Aerotop's biggest fan was going to sign in. Link to comment Share on other sites More sharing options...
