painting a polished intercooler
Bailey.
i have a greddy intercooler kit, all the pipework is not polished so wont be a problem to paint, but the actual intercooler is polished, how would i prep this for paint. reason being im painting the compressor housing rocker covers and inlet manifold in matt black hight temp paint, and the charge pipework is going a matt grey.
also would i have any issue with heat when painting the core?
Will painting it affect it's ability to cool?
I believe so, as the intercooler uses air to air it needs to be "fed" via the Tubes but I think (theoretically) the vent will be slightly smaller due to the paint covering a mm or 2. So hence giving less gap for the air to enter... So will affect slightly.
(theory)
Yeah the same, make sure the surface is clean and dry, and spray it on, you can get it in aerosol or in 1k form.
Yeah I've seen it in the halfrauds rattlecan section but didn't know about it so opted for zinc primer. But cheers, will def give it a go next time
Tbh its the only product I will prime alloy with fella. Never fails me.
Yep will bare that in mind. I used zinc primer but originally wasn't even going to prime as hammerite doesn't need primer. But juuuuust incase ima redo with the etch primer. Cheers for that
If its a dark looking cooler you want, fit black mesh in front of it, that way it tones it down and offers protection to a certain point.
tbh i really dont like mesh or grills at all, i think i will give the end tanks a couple of coats and then just a very very fine blow over of the core!very fine!
etch seems the way forward!:D
Back to topic:
"paint is cheap and easy to do, but it's a coating and may inhibit heat transfer, even using a heat transfer paint is debatable ... anodizing is simply an oxide dye so the intercooler still functions the same as unfinshed aluminum"
But...
"I think someone is wrong here. A basic rule for heat transfer in materials is that it relates to electrical transfer. This isn't 100% true all the time but mostly. Anodizing will not transfer electrical current. True it is very thin but if you ground your battery to an anodized surface your car will not start.
Paint on the other hand will work to help remove heat. That is why radiators are not natural but painted a flat black. That is why the SR-71 is painted black. Kelly Johnson did not want to do it because it was extra weight. He could have anodized it with no weight penalty. They took about 80f (I think) off of the surface with this trick. Of course they are talking about 900f to start with.
BTW that temp increase is due to pressure. So you see there is no way to get around compression producing heat. Even at 100% efficiency. On top of that they are working with air temps starting at minus 70f"
Back to topic:
But...
sorry, are u saying painting,,,,, may make it cooler???? to a degree....:D:D couldnt help myself!!!
