Nic Posted January 2, 2011 Share Posted January 2, 2011 And will a uk pack plug into a jdm loom or do you have to modify it? I think it'll need wiring in, but it's not something I've ever had to do so not 100%. Link to comment Share on other sites More sharing options...
Bailey. Posted January 2, 2011 Author Share Posted January 2, 2011 Thanks for the info nic, always appreciated. Can anyone else elaborate about fitting a uk resistor pack to a jdm car? Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2011 Share Posted January 2, 2011 Guide. http://www.internetwork.org.uk/Injectors/Injectors.htm Link to comment Share on other sites More sharing options...
Bailey. Posted January 2, 2011 Author Share Posted January 2, 2011 Guide. http://www.internetwork.org.uk/Injectors/Injectors.htm Very good guide that, seems simple enough, cheers Link to comment Share on other sites More sharing options...
Bailey. Posted January 2, 2011 Author Share Posted January 2, 2011 And idler bracket? Just seems to be a fortune for something an engineering shop could make quite simply? http://www.titanmotorsports.com/titan-billet-tensioner-2jz.html Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2011 Share Posted January 2, 2011 Get an engineering shop to knock one up then. Link to comment Share on other sites More sharing options...
Bailey. Posted January 2, 2011 Author Share Posted January 2, 2011 You understand where I'm coming from though, right? Link to comment Share on other sites More sharing options...
Blackie Posted January 2, 2011 Share Posted January 2, 2011 You understand where I'm coming from though, right? Theres an engineer on Mullacott i use all the time called R&R, They dont take the pi$$ on price too, Just explain what you want and they will do it. Link to comment Share on other sites More sharing options...
Bailey. Posted January 2, 2011 Author Share Posted January 2, 2011 Theres an engineer on Mullacott i use all the time called R&R, They dont take the pi$$ on price too, Just explain what you want and they will do it. All I have to do is make a few measurements for clearence and I will pop and have a word, what's the best material? Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2011 Share Posted January 2, 2011 Billet aluminum, just give them the stock cast one to copy, waste of time unless you are raising the rpm limit. Link to comment Share on other sites More sharing options...
Blackie Posted January 2, 2011 Share Posted January 2, 2011 Billet aluminum, just give them the stock cast one to copy Yep, Good idea Link to comment Share on other sites More sharing options...
Bailey. Posted January 2, 2011 Author Share Posted January 2, 2011 Billet aluminum, just give them the stock cast one to copy, waste of time unless you are raising the rpm limit. raising to 7500rpm max. as long as the turbo keeps pulling, pointless if the power tales off before! thanks blackie, when does the swap commence? Link to comment Share on other sites More sharing options...
JamieP Posted January 2, 2011 Share Posted January 2, 2011 It wont be the turbo that falls off the power at them revs, stock cams/valve train will. Link to comment Share on other sites More sharing options...
dandan Posted January 2, 2011 Share Posted January 2, 2011 I think those brackets are steel not aluminium. I definitely wold not bother with an aluminium one...but if my cams were interference I'd go for a steel one just for peace of mind. Link to comment Share on other sites More sharing options...
Bailey. Posted January 2, 2011 Author Share Posted January 2, 2011 It wont be the turbo that falls off the power at them revs, stock cams/valve train will. Im using whifbitz cams and bc valve springs and retainers, so should be good!!!! Link to comment Share on other sites More sharing options...
heckler Posted January 2, 2011 Share Posted January 2, 2011 Very good guide that, seems simple enough, cheers if need be - I can make you a resistor pack... Link to comment Share on other sites More sharing options...
Bailey. Posted January 2, 2011 Author Share Posted January 2, 2011 I think those brackets are steel not aluminium. I definitely wold not bother with an aluminium one...but if my cams were interference I'd go for a steel one just for peace of mind. yeah your right dan, Titan use billet steel. Link to comment Share on other sites More sharing options...
Bailey. Posted January 2, 2011 Author Share Posted January 2, 2011 if need be - I can make you a resistor pack... only just spotted your reply, can you pm me a price bud? Link to comment Share on other sites More sharing options...
Blackie Posted January 2, 2011 Share Posted January 2, 2011 thanks blackie, when does the swap commence? Its off on saturday mate Link to comment Share on other sites More sharing options...
Bailey. Posted January 9, 2011 Author Share Posted January 9, 2011 (edited) Anything wrong with these? seems a reasonable price. I have no need to upgrade my standard cooling setup(rad was replaced in 2009 iirc. but want to make the bay more visible, i.e pullies etc http://cgi.ebay.com/ebaymotors/Mizu-Radiator-Fans-Shroud-Kit-Supra-Turbo-93-98-97-96-/150424731642?pt=Motors_Car_Truck_Parts_Accessories&hash=item2306033ffa or possibly this? http://cgi.ebay.com/ebaymotors/MISHIMOTO-BLACK-Fan-Shroud-93-98-Toyota-Supra-JZA80-/190480019379?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ASupra&hash=item2c597e6fb3 Edited January 9, 2011 by Bailey. (see edit history) Link to comment Share on other sites More sharing options...
Bailey. Posted January 12, 2011 Author Share Posted January 12, 2011 Today i have ordered bc single valve springs and titanium retainers along with a bl oil pump and 3" weld on v-band flange and clamp. will the spending ever stop? I dont think so. Link to comment Share on other sites More sharing options...
Bailey. Posted January 13, 2011 Author Share Posted January 13, 2011 (edited) Final list, hopefully no more extra's!!!! -greddy turbo kit -precision 6765sp billet .84 divided -boost lofic oil feed and returns -750cc low impendence drop in injectors -Heckler resistor box -Bosch 044 fuel pump -sard fpr -veilside evolution exhaust -greddy fmic -k&n filter -4" graphite inlet pipe -hks fcon v pro management -blitz dual solinoid boost controller -hks afk knock amp and afr -competition clutch kit -competition ultralite flywheel -whifbitz cams 264 cams -brian crower springs and retainers -ferrera valve stem seals -ferrera lockers -oem water pump -boost logic oil pump -oem bottom pulley -blue gates racing belts -whifbitz purple pulley kit -whifbitz graphite/purple cam gears -whifbitz purple billet idler -whifbitz graphite baffled catch can -iridium ngk plugs -oem oil filter -driftworks oil cooler kit -black aeroquip pipe and fittings(fuel) -black silicone couplers -replacement coil pack clips -oem rocker gaskets -oem cam seals -oem exhaust manifold gasket -engineered steel tensioner bracket Extra's -uk 17's 9.5" on the front widened uk 8" to 11.5" rears -bf goodrich g-force T/A DR's 315,40,17 -1.75" wheel adaptors -rolled arches -hks hypermax 2 coilovers -powder coated charge pipes, rockers, and inlet mani. Already on the car -defi black face boost/egt/oil pressure/oil temp gauges -uk front and rear brakes with cw pads have i missed anything? I still cannot get hold of big jim ref. wheel widening:rolleyes: Do i go for an uprated head gasket or an oem replacement? Edited March 10, 2011 by Bailey. (see edit history) Link to comment Share on other sites More sharing options...
davej705 Posted January 13, 2011 Share Posted January 13, 2011 Great spec fella Link to comment Share on other sites More sharing options...
Bailey. Posted January 13, 2011 Author Share Posted January 13, 2011 Great spec fella cheers mate, should be good. Im drained, paid the remainder for oil pump, springs and retainers and seals and lockers last night! should be in the post early next week along with turbo and oil lines. I am near the finishing line. Then the hard work begins!!! Link to comment Share on other sites More sharing options...
Blackie Posted January 13, 2011 Share Posted January 13, 2011 my god thats a spec list! Link to comment Share on other sites More sharing options...
