Dave's GT45 6 speed aerotop
davej705
Hi and welcome to my build thread. Over the winter I will be attempting to convert my NA auto aerotop into a big bhp street monster.
I am going to be doing whatever jobs I can on the car but the majority of the work will be done by Lee p of SRD. I have enlisted the services of Lee p because he seems to know his way around a Supra ;)
I will be asking Ryan G of 2bartuning to map the car as his work speaks for itself :)
Bodywork is being taken care of by Noel of NUR motorsports and Rob of Darnley Auto Works (Mitchell9006). Rob will also be taking care of a few shiney bits under the bonnet for me. :cool:
Here is the planned spec so far,things will be added as the build progresses along;
Engine
GT45 turbo
Whifbitz twin wastegated manifold with 46mm Tial wastegates
SRD 3.4ltr stroker engine (billet crank,BC pro series rods,JE pistons and titan billet main caps)
Ported and polished head
ferrea 1mm oversize valves
Ti springs and retainers
HKS 264 inlet and exhaust cams
Greddy anodised pulleys
Greddy inlet manifold with Q45 tb
PHR triple hanger with 3 walbros (this may change)
Aeromotive fuel filter
Aeromotive FPR
Injector Clinic Fuel Rail -8AN
2150cc Injector Clinic Injectors
SRD fuel lines
SRD custom intercooler
Greddy oil cooler
The exhaust is going to be 4" from turbo back
Gearbox
V161 6 speed gearbox,prop,diff and shafts
undecided on clutch yet,gonna need to be strong...
ECU
Solaris ecu (I had one of thse on my Impreza project and rate them highly)
Brakes and suspension
K sport 8 pot 355mm fronts
K sport 6 pot 330mm rears
I will be using a performance pad,undecided on which yet,also change the lines and fluid
Not sure about suspension but I will be changing bushes etc to tightening everything up
Whiteline goodies
coilovers??
Exterior
NUR Motorsport carbon 47mm wider rear arches
NUR Motorsport custom wider front arch extensions
TRD Carbon Spoiler painted OEM black
Debadged
front Splitter painted OEM black (undecided on which one to go with)
Uk front headlights (facelifted)
RH 19" Split Rims 12.5x19 and 11x19
Interior
Defi BF series gauges (Oil pressure, fuel pressure, boost pressure and EGT and more to add to this soon)
Veilside racing evolution seats
Performance
I am aiming for a sub 10second 1/4 and a 200mph plus top speed
Here are some pics of the car in its current state
Edited by davej705 (see edit history)
  • Replies 246
Seems a shame to be using K-Sports with a build like this. Money spent everywhere other than where it counts on stopping.
Be nice to see some Brembos under them arches so you can stop the power that tubby will be running.
Don't mean to pee on your chips, good luck with the build look forward to the results.
Wow, this is going to be special :cool:
I'd probably opt for 2 Bosch pumps instead though after reading a bit about them recently. Also, are you going for an aftermarket plenum? The new PHR one looks like a great product. Also, how come you've opted for 264 cams instead of 280s?
These SRD cars are always fantastic :cool:
I will see how they are,if they aren't up to the job I will change them ;)
I read the same thread I think!
to be honest i will probably go with something other than HKS as there are better cams out there.
Going with a Greddy inlet for now...:innocent:
Uuuugghhhh. I'm going 3 pumps at the moment. * runs off to ring Lee*.
I would definitely rethink the 3 pump idea. I had a very close shave with the 3 Walbro route when one pump popped in dramatic style.
im going to copy whatever Lee does with Jamies new setup :innocent:
