1993-96 tt6 oem lsd
Hoppy
I've just fitted a TRD LSD, so i have this for sale chaps.
It's for a pre facelift 6 speed Supra, so it's for the large type diff casing.
It's in perfect working order. No weird noises and the bearings are mint.
I'll also include 2L of Kazz LSD oil, which was used with this diff for no more than 30 miles. So it's basically fresh oil.
http://img515.imageshack.us/img515/3987/p1010820m.jpg
Uploaded with ImageShack.us
http://img6.imageshack.us/img6/7443/p1010819p.jpg
http://img132.imageshack.us/img132/9892/p1010818i.jpg
http://img35.imageshack.us/img35/7863/p1010821v.jpg
£220 delivered
is this easy to fit to the casing that i already have on the supe? i have a pre facelift 1996 6 speed?
Took me approx 2-3 hours to remove this unit, and fit my TRD LSD. Below is a pic below showing the big and small casings. Your's should look like the one on the left (big casing), if so it's a straight fit mate. Just remove the diff casing from the car, remove the diff unit from the case, swap the crown wheel over from your old diff to this one, and then re-fit as removed.
http://img231.imageshack.us/img231/1316/299yk.jpg
  • 2 weeks later...
Damn - looks like mine is a little diff :(
Am I right to think that I'd need more than just the casing to make this fit? Different prop and different drive(half)shafts?
Yes mate, you would need all the mentioned parts to suit.
