Where to buy clips likes these,...
SupraStar 3000
The part no. for a weather strip clip is 90467-10146
There are 12 of them if you want to order a full set.
The weather strip itself is 53383-14110, just in case you wanted to replace it too.
The door clip ID is a bit of a gamble so here is a picture that you should be able to use to determine the correct parts yourself.
Also, your willy has made my day Ed :D
My willy makes everyones day :D
Why has that C and B got a walking stick ? :D
Its getting old mate. Lack of exercise is takings its toll.
Old Eddy Jr isn't a spring chicken anymore buddy.
I'm sure I've seen these in Halfrauds before now - have you check with them?
Popped into Halfrauds on the way home.
To be honest, I would have had more joy with the willy drawing.
Was told to go to Toyota - furry muff i thought.
There are hundreds of different clips used in every model of Toyota. Nissan will use different ones again, same for nearly all makes, it's a minefield and you need to go to Toyota and get the right ones for any certainty of a correct fit. Ask and bodyshop, total PITA, but there you go.
Great! Thats what I'll be doing this weekend then.
Great stuff. That might just help me identify the parts.
