Lude Posted October 18, 2010 Share Posted October 18, 2010 just had the car done (just about got on the ramp so low lol) the rear camber was awful, and the way itwas going through tires also was. cost me 140 for the full setup (camber, caster, toe) looks back to normal, and handled a lot better (was getting wobly feeling at high speeds. heres the results. they couldnt get the front spot on tho somehow cant remember? Quote Link to comment Share on other sites More sharing options...
dwayne Posted October 18, 2010 Share Posted October 18, 2010 toyota did mine and ever since then both front tyres wear more on the insides Quote Link to comment Share on other sites More sharing options...
Havard Posted October 18, 2010 Share Posted October 18, 2010 What is the difference between these geometry set ups. My local guy has a ramp which gives a similar readout and he only charges £35 + Vat. He spent nearly an hour setting up my NA and that handled fantastic afterwards. My TT is now being done on Thursday? Am I missing something? H. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 18, 2010 Share Posted October 18, 2010 Four degrees negative camber on the rear would indeed make tyre re-sellers smile Quote Link to comment Share on other sites More sharing options...
jackso11 Posted October 18, 2010 Share Posted October 18, 2010 I need to get mine done. Anyone know anywhere round my way (east london) that is good for this? Quote Link to comment Share on other sites More sharing options...
Stonkin Posted October 18, 2010 Share Posted October 18, 2010 I would speak to Tony at Wheels In Motion, slight journey for you but a very worth while trip. Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 18, 2010 Share Posted October 18, 2010 What is the difference between these geometry set ups. My local guy has a ramp which gives a similar readout and he only charges £35 + Vat. He spent nearly an hour setting up my NA and that handled fantastic afterwards. My TT is now being done on Thursday? Am I missing something? H. Full geometry setups are much more in depth than a laser tracker, depending on the machine. Our's has the ability to compensate for many changes like lowered suspension, rolling radius etc. We charge £45 for a standard setup and £100 for a custom one. Quote Link to comment Share on other sites More sharing options...
w41k3r Posted October 18, 2010 Share Posted October 18, 2010 Full geometry setups are much more in depth than a laser tracker, depending on the machine. Our's has the ability to compensate for many changes like lowered suspension, rolling radius etc. We charge £45 for a standard setup and £100 for a custom one. see £100 seems expensive but if the cars set up properly it can only be a good thing so money well spent Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 18, 2010 Share Posted October 18, 2010 see £100 seems expensive but if the cars set up properly it can only be a good thing so money well spent If you have ever had to do it you would know it involves a fair bit of work and testing and re adjusting to get the desired setup. I did mikes (M5WTT) a while back and that took the best part of 2 hours to do properly although not much time for testing as we only work to 12 on a saturday. Quote Link to comment Share on other sites More sharing options...
Havard Posted October 18, 2010 Share Posted October 18, 2010 see £100 seems expensive but if the cars set up properly it can only be a good thing so money well spent Defo is you get through a set of rears in 2k miles as £300 a go.... I'll just stick with my normal guy, he seemed pretty in depth in his workings..! H. Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 18, 2010 Share Posted October 18, 2010 If you go through a set of rears in 2k miles then there is obviously something not right with whoever set it up Quote Link to comment Share on other sites More sharing options...
Havard Posted October 18, 2010 Share Posted October 18, 2010 If you go through a set of rears in 2k miles then there is obviously something not right with whoever set it up Not me, that was an example of money being well spent.... Quote Link to comment Share on other sites More sharing options...
ShamelessTT Posted October 18, 2010 Share Posted October 18, 2010 Very expensive tho **For the midlanders, "Chemix" in the mids will do exactly the same for £70, same machine. Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 18, 2010 Share Posted October 18, 2010 Its all good saying oh they charge this much bla bla bla but 90% of the time they just reset the factory settings and make a couple of extra adjustments to which they think will cure the problem. There aint that many people out there willing to do a proper custom setup as its time consuming and expensive for the customer. Quote Link to comment Share on other sites More sharing options...
Nic Posted October 18, 2010 Share Posted October 18, 2010 if the cars set up properly it can only be a good thing so money well spent Definitely money well spent, a custom setup from someone who knows what they're doing makes a huge difference. Anyone who has fitted new wheels, suspension or hasn't had the geo checked in a while should definitely consider getting it done. Quote Link to comment Share on other sites More sharing options...
Lude Posted October 18, 2010 Author Share Posted October 18, 2010 (edited) i thaught that 140 quid was a lot, but as my rear tires were wearing awfully quick on the inside, and the price of a tire, its worth it! not just to make sure you have even tire wear, but it corrects the handling of the car, mine was quite wobbly, its much more noticable & solid ride now. plus the rear camber just looked a bit silly. so any comments on my figures above? previous ones & after? PS the owner of the garage said the machine cost 32k so im asuming a good job has been done lol Edited October 18, 2010 by Lude (see edit history) Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 18, 2010 Share Posted October 18, 2010 equiptment is only as good as the guy using it. Quote Link to comment Share on other sites More sharing options...
Lude Posted October 18, 2010 Author Share Posted October 18, 2010 equiptment is only as good as the guy using it. true. have the figures to show whats been done, and the rears were 4 & 3 degrees initially! so im happy thats been rectified you can just have the camber done, or the caster, or the toe, if you wanted to save money. thaught id get it all done & glad now Quote Link to comment Share on other sites More sharing options...
Nic Posted October 18, 2010 Share Posted October 18, 2010 The standard settings will be on here somewhere http://www.turbosupras.com/pdfs/JZA80%20TSRM/SA.pdf Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted October 18, 2010 Share Posted October 18, 2010 I've just had a quote for £520 from Centre of Gravity. That was for a full setup. They take it for a day, but I think that's a little steep! Quote Link to comment Share on other sites More sharing options...
