Blackie Posted October 17, 2010 Share Posted October 17, 2010 As the title really, I guessing they are identical and the prop will fit and everything? Cheers Link to comment Share on other sites More sharing options...
JustGav Posted October 17, 2010 Share Posted October 17, 2010 Nope... not at all Link to comment Share on other sites More sharing options...
Blackie Posted October 17, 2010 Author Share Posted October 17, 2010 Nope... not at all So what do i need? Just the tt autobox ecu or the prop as well? Link to comment Share on other sites More sharing options...
JustGav Posted October 17, 2010 Share Posted October 17, 2010 So what do i need? Just the tt autobox ecu or the prop as well? The internals of the TT A340E are different, it has additional clutches plates and solenoid controls and a few other bits.. LOT of work to get it done.... Probably better off getting a NA one and upping the line pressure and reshimming. TT autobox ecu (and the Na one) are part of the engine ECU.... If you were feeling REALLY brave I suppose you could piggy back the two together feeding certain signals, but I suspect that would be a nightmare. Link to comment Share on other sites More sharing options...
Blackie Posted October 17, 2010 Author Share Posted October 17, 2010 Probably better off getting a NA one and upping the line pressure and reshimming. . Whats that then Gav? I have an N/A autobox with an ECU already and a TT autobox with no ecu BUT the engine i have coming has a TT ecu with it (For the engine) I'm confused Link to comment Share on other sites More sharing options...
Blackie Posted October 17, 2010 Author Share Posted October 17, 2010 (edited) last question, So if i get a TT autobox ecu it will all be fine? Bearing in mind i will have a tt engine ecu too. Theres no way i can run a N/a autobox on a TT engine? Edited October 17, 2010 by Blackie (see edit history) Link to comment Share on other sites More sharing options...
JustGav Posted October 17, 2010 Share Posted October 17, 2010 You are confused? so am I Okay, If you run an NA engine, you will need the NA ecu, part of the NA ECU internally is the gearbox controller. The NA and TT autoboxes are different enough to make interchanging them a waste of time. HOWEVER if you are going TT swap then you will have the TT ecu (with the internal TT gearbox), so then that combo will work with the TT gearbox. In short, NA engine will have to have NA gearbox and vice versa. Link to comment Share on other sites More sharing options...
Blackie Posted October 17, 2010 Author Share Posted October 17, 2010 RIGHT, I have a tt engine coming with ecu, I got a tt gearbox yesterday. Am i right in thinking there is only ONE ecu for the entire car and not a seperate one for the gear box as i thought? Link to comment Share on other sites More sharing options...
JustGav Posted October 17, 2010 Share Posted October 17, 2010 RIGHT, I have a tt engine coming with ecu, I got a tt gearbox yesterday. Am i right in thinking there is only ONE ecu for the entire car and not a seperate one for the gear box as i thought? Yes, there is only one box of gizmos for engine and gearbox. Make sure you get a loom with the TT gearbox as well as they are slightly different. Link to comment Share on other sites More sharing options...
Blackie Posted October 17, 2010 Author Share Posted October 17, 2010 Yes, there is only one box of gizmos for engine and gearbox. My dont i feel silly, I thought the gearbox had its own ecu. Cheers for your help mate Link to comment Share on other sites More sharing options...
JustGav Posted October 17, 2010 Share Posted October 17, 2010 My dont i feel silly, I thought the gearbox had its own ecu. Cheers for your help mate Nah man, better than trying to put it all together and sitting there scratching your head (ooo'errr) Link to comment Share on other sites More sharing options...
Blackie Posted October 17, 2010 Author Share Posted October 17, 2010 Nah man, better than trying to put it all together and sitting there scratching your head (ooo'errr) I will just text you next time Link to comment Share on other sites More sharing options...
edge Posted October 17, 2010 Share Posted October 17, 2010 what propshaft will he need to fit the tt autobox to his na diff? Link to comment Share on other sites More sharing options...
Blackie Posted October 17, 2010 Author Share Posted October 17, 2010 what propshaft will he need to fit the tt autobox to his na diff? I would think it's the same prop as the tt and n/a autobox have the same castings? And whe you say "he" don't you mean you Carter and Jimmer? Link to comment Share on other sites More sharing options...
Nodalmighty Posted October 18, 2010 Share Posted October 18, 2010 If you happen to have the TT and NA auto, see if the valve block from the NA will fit the TT box (check all fluid passages align and post some pictures). Link to comment Share on other sites More sharing options...
JustGav Posted October 18, 2010 Share Posted October 18, 2010 If you happen to have the TT and NA auto, see if the valve block from the NA will fit the TT box (check all fluid passages align and post some pictures). There are apparently some bits you can swap, but that would scare me, and with Al I'd reckon he would pass on that sort of operation... (I can just picture one of the shims flying out and belting him on the forehead ) Link to comment Share on other sites More sharing options...
Blackie Posted October 18, 2010 Author Share Posted October 18, 2010 There are apparently some bits you can swap, but that would scare me, and with Al I'd reckon he would pass on that sort of operation... (I can just picture one of the shims flying out and belting him on the forehead ) Yeah I think I will pass on that. So as Edge asked what prop would I need to join the tt autobox to my n/a diff. My na prop will fit I'm guessing? Link to comment Share on other sites More sharing options...
