wheel fitment help please
Guest puregttipower
Guest puregttipower
Hi guys please move if in wrong area, seen some wheels i really want here is the spec of them
19x10 et 40 front
19x10 et 15 rear
will these fit a standard arched supra? or what work would be needed? ;)
19x10 et 40 front
19x10 et 15 rear
Completely unsuitable for a Supra if you value the handling. The rears would stick out way past the wheel arches. Also 19" wheels will do nothing for the ride quality.
On a stock bodied Supra you want a staggered set up such as:
Front 19 x 9 (offset between +50 & +35)
Rear 19 x 10 (offset between +50 & +35)
or
Front 19 x 8.5 (offset between +50 & +35)
Rear 19 x 9.5 (offset between +50 & +35)
If you have the larger 4pot/2pot brakes fitted you will need to make sure the wheels will clear the calipers.
