jackso11 paintwork
Rob_Mitchell
is the roof panel still on there? opr are you doing the rest first then taking that off to paint it after?
I am a bit confused as to why the bit between the boot lid and the roof panel is not being painted as you are doing the sides of that strip and the roof panel. I don't know if thats normal mind you, just asking.
  • Replies 144
Cool, thanks. I have all 4 seal, both sides of the roof and the front and back that are stuck on the body. Not sure what you are taking off with the work but whatever you take off please put the new ones back on. I also have a new set of the popup eyebrows.....if you don't know what they are you will see when you take the roof off :D the ones on there have rust joints so don't move properly. If they need to come off you can leave them off. In fact, I don't know how the front seal bonds on but if it is over the top of the eyebrow screw on plate best elave that seal for me to do.
That sounds confusing but will make sense when you take the roof off :D
The bit that is confusing me though is the bit I highlighted in the picture attached, does that bit not need painting as the rest is all being done? Its the strip of roof that goes between the roof panel and the boot.
ahhh, got you.
I need to learn to stop sticking my nose in.....but I like to know what is going on.
Didn't mean that to sound like 'do that bit' by the way, more like 'I wonder why that bit doesn't need doing'. I just ask too many questions. haha
I like the brown paper hat look. Maybe I will just cut eye holes and leave it like that. :D
