mellonman Posted October 15, 2010 Share Posted October 15, 2010 All i see these in america siemens deka 650 with fuel rail are they any good ? Static Flow Rate (GAS): 62.7 lb/hr = 650 cc/min Dynamic Flow Rate 2.5ms PW @ 100Hz (GAS): 20.2mg/pulse Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers) Gain: 0.11ms/mg Offset: 0.055ms Turn on time @ 14VDC: 1.14ms Turn off time: 0.85ms @ 600KPa Factory Tollerance: +/-6 % Spray Pattern: Cone (4-Hole) Connector: (Bosch EV1) Quote Link to comment Share on other sites More sharing options...
