Miles to KM converter
Black_Supra
you need to search on this forum for mph to km converters
your car has had km from the begining and been converted to mph along the way (if you dont have a ukspec sold in the uk)
the little gadget/converter is easy to remove once you find it and then just put the wires back in the correct order and your car will do kmh instead of mph
it is usually down on the passenger side close to the pink wires by the ecu but can also be behind the dashboard up under the speedometer.
(i have done this a couple of times and its easy after you done it :-) the first time)
so search the forum i even think its a sticky in the technical how to section.
good luck
