Do i need permission from council?
erol_h
My house is the 1st house on the street and due to this i have a 3m wide gap between my house and the property wall. Ive recently put down concrete and slabs so i can park my car in the gap. I want to put a roof that will attach to the side of my house and rest on the wall on the opposite side covering the car i will park there. I will need to raise the brick wall i already have by going higher by 3 bricks more. Do i need permission for this kind of work or can i just go full steam ahead.
Im sure 6ft 6" is the maxium height of a boundary wall but there are conditions that you cant go that high if its blocking light to neighbours etc.
If it was my house i would just do it and take the risk on being caught out, im not advising you do that though.
Any pictures of the area?
http://www.planningportal.gov.uk/uploads/hhg/houseguide.html
http://www.planningportal.gov.uk/uploads/miniguides/outbuildings/outbuildings.html
http://www.planningportal.gov.uk/england/public/buildingwork/projects/workcommonextensionreal/
http://www.planningportal.gov.uk/england/public/buildingwork/projects/workcommonfenceswallsgates/workmoreppfencewallgate
Some infotainment links for you.
If you put a roof over it, sitting on the boundary wall (raised or unraised), whadddaya going to do with the rainwater?
Also why pay so much for extra brickwork to only raise 3 courses, 225mm? Why not just do that in a timber wall plate and upstand for the joist ends. That way if you do get any planning trouble and are forced to remove it, you'll only be losing some timber. New brick onto old is always going to be visible for many years.
im still waiting for the exact quote as im getting a quote from 3 different builders but i have been told it should be roughly between 3 to 4k. Its going to start where the 1st post is on the wall stretching across the 3rd post. Im going to have wooden support beem going up each post to help with the load. Also remove the fencing between the 3 posts and brick them up.
the reason i want to fill up with bricks is to make it more secure and less visible to everyone else. Its not in the pic but i have planted trees from the back of the garden all along the wall that stops exactly where the roof is going to be and stops people from seeing into my gardebn.
