spiderpigcity Posted October 14, 2010 Share Posted October 14, 2010 do i need a spiggot bearing for my auto or will the output shaft go straight in to the 6 speed? Quote Link to comment Share on other sites More sharing options...
David Reid Posted October 14, 2010 Share Posted October 14, 2010 Yes, you need a spigot bearing as they are different size auto to manual. I had to do the same with mine. It will fit together as the auto is bigger than the manual, but if you dont have the correct size you will wear/break the input shaft bearing. Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted October 14, 2010 Author Share Posted October 14, 2010 Yes, you need a spigot bearing as they are different size auto to manual. I had to do the same with mine. It will fit together as the auto is bigger than the manual, but if you dont have the correct size you will wear/break the input shaft bearing. dave ,, dont suppose you have the part number for the bearing i need to order? also i suppose its worth changing the rear main seal while the box is off? Quote Link to comment Share on other sites More sharing options...
keron Posted October 14, 2010 Share Posted October 14, 2010 90363-12002 dave ,, dont suppose you have the part number for the bearing i need to order? Also i suppose its worth changing the rear main seal while the box is off? Quote Link to comment Share on other sites More sharing options...
