dr_jekyll Posted October 14, 2010 Share Posted October 14, 2010 evning all. bit of a strange one hear. the last time i used my blue supe was the club trackday at llandow and the car was andling beautifully. felt balanced and planted. now today is the first time iv taken the car out since then and it seems to have a developed a handling issue. when going in a staight line , if you give a bit of pedal the car pulls one way,and if you lift it sort of kicks back the other? and secondly on tightish cornering the car feels like it has rear wheel steer for all those who have driven the preludes. now iv gone through the obvious . there is zero play in either rear wheel , bushes are all solid . checked all the subframe bolts. , tyre pressures are fine . the geo was fully set up before the track day and as said that day it was superb. ill have the geo tested again on the weekend but anything obvious ive missed? after i removed and replaced the bolt flange on my diff, dude mentiond something about backlash on the cogs that im clueless about could the nut torque being wrong cause this ? all ideas much apriciated as ever. craig Quote Link to comment Share on other sites More sharing options...
Robzki Posted October 14, 2010 Share Posted October 14, 2010 Sure all bushes are ok? especially the upper wishbones(rear). Mine was behaving like this, had minimal play in the upper wishbones, replaced and problem sorted Drove 'ok' but had alarming rear wheel steering when accelerating hard or decelerating Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 14, 2010 Author Share Posted October 14, 2010 well iv been uder there with a pry bar and they wont budge , this was the first thing i thaught Quote Link to comment Share on other sites More sharing options...
Supra-Brett Posted October 14, 2010 Share Posted October 14, 2010 its sometimes hard to tell if bushes/suspension components are knackered until they are under full load. Bar is sometimes not enough to diagnose. I had problem with knovking at the rear. No one could see anything wrong. Replaced shocks and springs aand all was fine, yet ones that came off also looked fine. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 14, 2010 Author Share Posted October 14, 2010 well iv just gone through my box of tricks and i have a spare set of rear top wishbones so i think ill pollybush them, fit them , have the geo reset and see if tha cures it. Quote Link to comment Share on other sites More sharing options...
fuldhat Posted October 14, 2010 Share Posted October 14, 2010 Please post the results. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 14, 2010 Author Share Posted October 14, 2010 i will mate, bloody car Quote Link to comment Share on other sites More sharing options...
ellis Posted October 14, 2010 Share Posted October 14, 2010 Seized brake caliper? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 14, 2010 Author Share Posted October 14, 2010 Seized brake caliper? oo good one . possibility, they have recently been on fire. iv got new pads from chris wilson arriving tomorrow so ill inspect when i take thm off. but would this be responsible for the edgy rear in the corners? Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted October 14, 2010 Share Posted October 14, 2010 My money is on a caliper too. Makes sense after you've caned them on a track. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 14, 2010 Author Share Posted October 14, 2010 yea i hope so. that would make sence, cant belive i didnt think of that. but then thats why i started the thread sod it ill go check now Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 14, 2010 Author Share Posted October 14, 2010 car lifted and all wheels spin freely Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted October 14, 2010 Share Posted October 14, 2010 Yeah, check your calipers dude, a slider could still be stuck. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 14, 2010 Author Share Posted October 14, 2010 ill have a propper investigation tomorrow , results to follow Quote Link to comment Share on other sites More sharing options...
J_Supra_07 Posted October 14, 2010 Share Posted October 14, 2010 Just a idea put the other set of rims on, test it. Will let u know it's not the Tyers or wheels. I'd go for brakes sticking after u cooked them. Quote Link to comment Share on other sites More sharing options...
Suprash Posted October 15, 2010 Share Posted October 15, 2010 I've had exactly those simptons before when I was running a directional tread backwards ? Quote Link to comment Share on other sites More sharing options...
w41k3r Posted October 15, 2010 Share Posted October 15, 2010 when my calipers went it was easy to tell the alloys were hot to touch after i short drive could try that Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 15, 2010 Author Share Posted October 15, 2010 I've had exactly those simptons before when I was running a directional tread backwards ? its on assyetric tyres , if i put directionals on backwards id shoot myself in the head.... twice anyways, today i have fitted new brake pads and new fluid. been under the car with a bigger bar and im confident its not the wishbone bushes, they are real stiff and i have to go wild to get the slightest amount of play. the only thing i have to hang onto is the rear right caliper piston was noticeably harder to push back then the other three. its not siezed solid , it dose move, but verry stiff? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 15, 2010 Author Share Posted October 15, 2010 next update iv just pressed the rear caliper back so the are well off the disc and taken the car for a run and it still has the left twithch. the mot testers next door have also had a look at my suspension for exess play and they say its fine too?? im stumped. for now ill just have to put it down to my 7psi is obviously making 1000 lbft of torque and is twisting the chassis Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 15, 2010 Share Posted October 15, 2010 What's the rear tyre wear like? Even, or inner edges worn? Tyre pressures even? Tyre make and model the same both sides at the rear? My first guess would have been inner top rear wishbone bearings, then rear toe control arm bushes / ball joints. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 15, 2010 Author Share Posted October 15, 2010 pirelli p-zeros x4 285/35/18rear 245/40/18front, 32psifront with 30 psi rear. wear is perfect, no graing or tide marks on any edge. i thaught it would be the reat tops but theyve only been on about 18 months . those front pads are superb by the way. huge difference from the cheap ebc tat. thanks Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 15, 2010 Share Posted October 15, 2010 Glad you like the pads. Wish I could help more with the ill handling. The only other thing that comes to mind is if the rear toe is correct, cumulatively, but offset from the vehicle centreline, causing a thrust vector. I wish I could draw and just send as an attachment easily, it's much easier to show than tell. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 15, 2010 Author Share Posted October 15, 2010 well i had the geo reset before llandow ... but i did take a big spin and bounce across the kerbs so its going for another check and set up when i get time . hopefully one of my wheels is a few degrees out and all will be sorted. i actually think understand what your saying about the incorrect toe causing the direction change under load so fingers crossed Quote Link to comment Share on other sites More sharing options...
Steve Posted October 15, 2010 Share Posted October 15, 2010 Just a idea put the other set of rims on, test it. Will let u know it's not the Tyers or wheels. I'd go for brakes sticking after u cooked them. The word you are looking for is 'you' not 'u'. Quote Link to comment Share on other sites More sharing options...
ellis Posted October 15, 2010 Share Posted October 15, 2010 I once had an MGB GT that shimmied left under acceleration and right under braking - the rear subframe bolts were loose. Worth checking yours? Quote Link to comment Share on other sites More sharing options...
