The-Plethora Posted October 14, 2010 Share Posted October 14, 2010 Hey all I seem to be taking a financial hammering this month with the MOT coming up. Seems to be the starter motor this time, the battery was bought new last weekend so I dont think that is the problem. Can you have a quick look at the hastily recorded vid below and see if you reckon it is the infamous click that indicates a knackered starter? If so I can probably order one today and hopefully get it fitted on the weekend, looks quite involved and I need to get some axel stands! UCU1WKebfQE Cheers again Dave Link to comment Share on other sites More sharing options...
Geo Posted October 14, 2010 Share Posted October 14, 2010 dont sound like the starter to me, your getting ''click'', duff starter should be like, click, click, click, click. daft question, have you tried jumping her?? Link to comment Share on other sites More sharing options...
Guest blueangel Posted October 14, 2010 Share Posted October 14, 2010 hey at least you have fuel sorry i cant be any help Link to comment Share on other sites More sharing options...
Matt H Posted October 14, 2010 Share Posted October 14, 2010 Sounds like it could be battery - I'd start there before replacing your starter. Link to comment Share on other sites More sharing options...
The-Plethora Posted October 14, 2010 Author Share Posted October 14, 2010 The battery is 3 days old, when the car was sluggish to do anything on the weekend we tested the battery which was dead it was replaced and things seemed ok again. I drove the car recently and tried to start it a few times and got this 'click' after about the 10th time it fired up ok thats why I am leaning towards the starter and reading about people saying the it gets harder and harder to start (damaged contacts) which seems like what I am experiencing. Link to comment Share on other sites More sharing options...
dwayne Posted October 14, 2010 Share Posted October 14, 2010 can you check the battery to see voltage drop while you are turning the key? i had a brand new battery once that wouldnt even hold charge so i swapped it and that didnt work either. took it back for a second time and they checked a few batteries in front of me that were all new and faulty. its worth checking if possible so you dont spend cash you didnt need to Link to comment Share on other sites More sharing options...
stevie_b Posted October 14, 2010 Share Posted October 14, 2010 Have a look here: are these the symptoms you're getting? -> http://www.mkivsupra.net/vbb/showthread.php?t=70712&highlight=starter+motor I've had a listen to your YouTube video, and and it sounds like it could be worn starter motor contacts. Starting up eventually is a classic sign of this. Bear in mind that you rarely need to buy a whole new starter motor. The contacts are the bit that need replacing, and Toyota sells these separately. Double-check that the battery connections are nice and tight. I use vaseline to ensure a good electrical contact. Link to comment Share on other sites More sharing options...
The-Plethora Posted October 14, 2010 Author Share Posted October 14, 2010 I will give the car more of a going over this evening, it was just before work so didn't have much time. So general thoughts are starter motor or starter motor contacts? Stevie the behaviour is the same as your linked thread, the fans come on and everything else seems fine, radio works, plenty of power. When it does actually start it starts fairly easily and catches just fine. Either getting a new starter or a refurb kit still means getting under the car and getting my hands dirty, ah well. Dumb quetion but UK and Jspect starters are identical right? Debating refurbing or just replacing something thats 15 years old anyway. Link to comment Share on other sites More sharing options...
adam1983 Posted October 14, 2010 Share Posted October 14, 2010 (edited) This happened to me last year and it turned out that it was just loose connections on the battery. All i had to do was tighten them up and it was fine again. Was really embarrasing when it happened to me though as i was at the petrol station having just filled up. Popped the bonnet and gave the leads a quick jig and everything seemed fine. Tightened them both properly when i got home and had no problems since. Hope this helps Just read your previous post properly and read that you are getting power. Guess it cant really be the connections at the battery then. Edited October 14, 2010 by adam1983 (see edit history) Link to comment Share on other sites More sharing options...
marbleapple Posted October 14, 2010 Share Posted October 14, 2010 This happened to me last year and it turned out that it was just loose connections on the battery. All i had to do was tighten them up and it was fine again. Same as me. Except withy mine I posted a thread on here begging for help, bought a new alternator and then broke down outside a closed garage and had to wait for an AA man to come along and give me a jump start (and connect the cable to the battery properly) Link to comment Share on other sites More sharing options...
The-Plethora Posted October 14, 2010 Author Share Posted October 14, 2010 Just waiting on a local place to quote for a new starter for a 93 - 96 model (So UK then). Same for a Jspec right? Link to comment Share on other sites More sharing options...
Geo Posted October 14, 2010 Share Posted October 14, 2010 Just waiting on a local place to quote for a new starter for a 93 - 96 model (So UK then). Same for a Jspec right? just buy the re-furb kit dude, i did this to mine, and works a treat. its just a pack with the copper contacts, easy job Link to comment Share on other sites More sharing options...
marbleapple Posted October 14, 2010 Share Posted October 14, 2010 just buy the re-furb kit dude, i did this to mine, and works a treat. its just a pack with the copper contacts, easy job I get one second hand perhaps? Geo, your Avatar makes you look like the guy from Pineapple Dance Studio you know..... Link to comment Share on other sites More sharing options...
The-Plethora Posted October 14, 2010 Author Share Posted October 14, 2010 Hmm seems refurbing is the way to go. One of the posts from SupraLoopy shows the following part numbers are needed 28226-74070 28226-22050 I will give toyota world a ring and see what it costs, hope its the same for UK and Jspec starters. Link to comment Share on other sites More sharing options...
Ambrose7 Posted October 14, 2010 Share Posted October 14, 2010 This is the exact same problem i have at the moment, it starts up after about 10 tries, then all's fine, i replaced the battery with a new one just in case, but its exactly the same, its going in for a service on monday so ill order these parts and give them to the garage Link to comment Share on other sites More sharing options...
The-Plethora Posted October 16, 2010 Author Share Posted October 16, 2010 SWEET JESUS! What have I started! £19 for the kit and spent about an hour removing this chunk of metal off the car and now feel the need to topple old ladies and steal sweets from youngsters. Its like some sort of rite of passage, never ever again am I removing this thing! WHAT A BITCH! Prepare for more dumb questions as I try to remove bolts and lose bits, time for a coffee, not even halfway through yet! Link to comment Share on other sites More sharing options...
TopgunTT Posted October 16, 2010 Share Posted October 16, 2010 Well done for giving it ago yourself mate Link to comment Share on other sites More sharing options...
dwayne Posted October 16, 2010 Share Posted October 16, 2010 dont forget to take plenty of pics, you could make a guide for doing it (if there isnt one here already) Link to comment Share on other sites More sharing options...
The-Plethora Posted October 16, 2010 Author Share Posted October 16, 2010 Well.... that took probably 5 hours in all! I think it would be at least 10 times easier with access to a 4 post lift. But...she lives! fired up first time and had a couple of starts since, was it bit worried as its the law of the sod that when its all back together you get the same problem. I will leave the vid up and add the part numbers incase anyone else happens accross it and finds it useful. I was a bit worried as I only got the single click rather than click click click on starting that people mentioned but it's deffinately done the trick. Thanks SupraLoopy for the guide, it was a lot of help. Right time to get rid of the oil and blood I seem to be covered in... Link to comment Share on other sites More sharing options...
