Drive shaft balancing
spiderpigcity
yes but i didnt mark the middle where it split
But if both prop ends are marked and the box and diff are marked surly when you put it all back it will line up. Been a while since i have been under a supra but i cant remember how the middle splits?
The two halves are joined using splines just forward of the centre bearing. There must be about 20 different ways the two halves could fit together if you kept the gearbox end steady and rotated the diff end.
I made the mistake of putting a matchmark on the rubber boot that covers the splines. I forgot that the boot rotates quite easily. Doh! I've not noticed any vibrations from the prop after just putting them together without marks.
Ah i see now. I thought it was only 4 bolts in the middle :rolleyes:
Yeah that :)
So, if the props come in 2 parts, could you not buy 1 half of X prob and fit it to the other half of Y prop?
Yeah that :)
yes you can but you would have to have them balance or you will finish up busting your diff and your gearbox and crank bearings. and ultimatley have a shaft come through your car and killing you. i have a prop shaft come off on me a few years back and it dug into he m1 and shot blasted the roof of my car with grit and tarmac. and im not joking, i was lucky it didnt flip my car over. but they can come up through the floor and impale you as well. also if you have a badly balanced prop shaft it makes the whole car vibrate 10 times worse than wheel wobble.
:blink:
Because the RPM is so much higher :) Dynamic balance ftw. As the Edgester says though, if the props now in 2 pieces, and both ends are marked up independantly you should be able to refit it with no worries.
i only marked the props to the flanges not the casings, so i dont see how i can put them back? or maybe i am having a blonde moment
:eyebrows:
Providing the flanges and casings havent moved it should be simples. If they have then youre right to get it balanced properly :)
i spun the prop shaft flange on the diff around when i dropped the diff just to make sure both the half shafts turned the same way to make sure it was a torsion diff, not open. so i guess i am fubared!:blink:
The reason for split prop shafts are two fold. Angularity of gearbox output fange to diff output flange ( split a big angular cahnge into two smaller ones), and harmonics down the propshaft.
There is a correct phasing for Hardy-Spicer joints, it's apparenntly quite simple to re-phase them correctly. Reco-Prop will probably tell you how to do it. They will probably be 180 degrees out of phase.
