hodge Posted October 13, 2010 Share Posted October 13, 2010 Hi guys I'm trying to tighten up my crank pulley bolt but having no success. Normally with a stock pulley I'd use a pulley locking tool and tighten it up that way but I've got a Titan pulley and have nothing to attach a locking tool too. I've tried sticking it in gear and tightening it but it turns a little and goes well spungy and wants to spring back if that's the right description. Now the bolt does seem reasonably tight now but I can't imagine it's at the correct torque setting. Any ideas. I thought of sticking a bar in the wobble joint at the front of the prop where it attaches to the box but wasn't sure how much pressure it would take TBH. Quote Link to comment Share on other sites More sharing options...
TLicense Posted October 13, 2010 Share Posted October 13, 2010 Not the most elegant solution, but it'll work. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 13, 2010 Share Posted October 13, 2010 1/2" drive impact gun pnumatic FTW Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted October 13, 2010 Share Posted October 13, 2010 i used an old leather belt and adapted an oil filter strap type wrench,wrapped belt around pulley and tightend.then got someone else to tighten the bolt, better with 2 people though but worked. Quote Link to comment Share on other sites More sharing options...
hodge Posted October 13, 2010 Author Share Posted October 13, 2010 i used an old leather belt and adapted an oil filter strap type wrench,wrapped belt around pulley and tightend.then got someone else to tighten the bolt, better with 2 people though but worked. I don't know why but this just made me chuckle. Imagine a massive tuning shop the likes of Titan wrapping a leather belt around a pulley to tighten it. Awesome. Then again mate if it works it works. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 14, 2010 Share Posted October 14, 2010 Lock up the ring gear, either with a fixture bolted on in place of the starter motor, or with a blunt long steel chisel through a .75" hole drilled in an appropriate place in the bellhousing. With the chisel some other party will need to hold it. Quote Link to comment Share on other sites More sharing options...
