How to replace pass/drivers glass
gazzi123
I bought pass/drivers glass from Rob few days ago.
Ive given them a complete clean and look brand new from all the glue the tints left behind + Look real nice.
But has anyone got a step to step guide of how to replace the windows/get them in/out properly??
Cheers peeps
Simples.
Get door card off.
Remove door handle.
Remove door handle wire holder thing.
Get behind plastic sheet (with the horrible glue that sticks to your clothes and never comes off).
Remove what was holding that handle wire holder (big flat piece of metal).
Make sure that the window is down and unbolt the three attached areas.
Pull the window from the door.
Be care that you align the window right when replacing it! You don't want to end with a smashed window because it wasn't aligned properly.
Are you on about the door glass mate? If So could not be easyey just remove the door card then locate the 3 bolts which hold it in and remove the once undone the glass will just lift straight out then just do the reverse to refit should have it all done in half hour a side .
